3rd Party Batteries for Panasonic 2013 HS-V210 V520 V720 etc.. WHERE ARE THEY!? - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2013, 11:19 AM - Thread Starter
mr-scorpio's Avatar
Hi there,
I'm new to AVS so please be gentle ;-D
A question about Panasonic batteries & 3rd party versions like Wasabi.
It seems that despite Panasonc's 2013 range of camcorders being out months & months now,
I'll be damned if i can find ANY 3rd party equivalents to the VW-VBT190 & VW-VBT380..
It's annoying because you can easily get a 4000mAh VW-VBK360 equivlent for as little as £20! -2012 model camcorders.
However we're still being forced to be ripped off over £100 for a VW-VBT380!!! - And that's if you can get them!!
I tried the lug-remove trick on a VW-VBK360 oem & alas, even though it fitted my HC-V210, i got the predictable: "THIS BATTERY CANNOT BE USED" error.
So does anybody know what gives? WHY after montths, are there still no 3rd party batteries out for the 2013 camcorders?
When might there be?
Hope someone has some answers,
All the best
Al
mr-scorpio is offline
Old 07-19-2013, 12:46 PM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
The whole point of Panasonic changing battery design every few years is to have a lead over third-party knockoffs, so Panasonic could sell you a $25 battery for $120. Ripoff ==> profit. Gee, almost a palindrome.
Ungermann is online now
Old 07-20-2013, 01:51 PM - Thread Starter
mr-scorpio's Avatar
Hi,
Thanks for the reply, even though you didn't actually answer the question.
I already realise all you said. My question simply is... Given that these cams HAVE been out practically half a year already, WHY haven't 3rd party battery makers brought out their equivalent versions by now? Or does it actually take then at least 6 months to 'catch up'?
I look forward to an answer from someone who knows.
Cheers
Old 07-22-2013, 03:50 AM - Thread Starter
mr-scorpio's Avatar
Bump....
Old 07-22-2013, 11:13 AM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
I can give you another non-answer: it took 4 years for third-party VBG batteries to become available. It took 2 years for third-party VBN/VBK to appear. Judging by the numbers above 6 months would be a breeze.
Your guess and my guess are as good as anyone else's if you are not tightly connected with Chinese manufacturers of counterfeit (as Panasonic refers to them) batteries.
Old 06-06-2014, 01:59 PM
Benja's Avatar
Hi,
According to the link below it looks like manufacturing is not the bottleneck here:
http://www.alibaba.com/for-panasonic-vw--vbt380-battery-suppliers.html
AVS or other retailers can purchase at $11.5 a piece and sell for 30-40 Dollar. After import, taxes, etc it should still give them a 20-30 percent revenue. Maybe it is still not enough. I am looking for a replacement battery that lasts more than 45 minutes. Let me know if you find a place to buy.
Benja is offline
Old 10-03-2014, 08:25 AM
Liked: 0
I purchased the vbt360 battery and took it apart and the reason that the batteries will not work is due to a chip imbedded inside the battery. All they do is change out the chip and they prevent the camera from using old batteries. There is a trick/work around to this though. One is a plug and play option that I discuss on my website here my-home-workshop.com/232/ There are also pictures of the battery and the inside of the battery.
The other option is to purchase a vbt360 battery and take apart your 190 battery, solder the extra battery cells to the 190 battery and glue the 360 case to the new 190 battery. I didn't try this, but it should work because the batteries are built with a series of cells in parallel. The plug and play option mentioned above yields an much larger battery, probably up to 5x larger than the vbt380 battery for about $50. It works well for me.
Daniel Dodd is offline
Old 10-03-2014, 10:09 AM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
I am surprised no one has sued Panasonic yet for this anti-consumer practice.
