Sony PJ790 issue... anybody else....? - AVS Forum | Home Theater Discussions And Reviews
Old 08-06-2013, 05:53 AM - Thread Starter
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
It seems that every so often the cam just simply and randomly stops operating. It appears perfectly dead, even with a charged battery. What I have to do is remove the battery for a minute and that seems to clear the problem.... until the next time. Not a big deal I guess, but I'm just trying to find out if this is a unique issue or others have the same problem.
bigbarney is offline
Old 08-07-2013, 12:48 AM
spyker1212's Avatar
Quoted: 105 Post(s)
go to 'General Setting'
then 'Power Save'
set 'Standard' to 'Off'
spyker1212 is online now
Old 08-08-2013, 05:52 PM - Thread Starter
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
Thanks. I'll see if that does it.
Old 08-09-2013, 12:00 AM
spyker1212's Avatar
Quoted: 105 Post(s)
if you want to keep the power save on so as not to drain camcorder battery fast.
once the camcorder automatically turned off. you don't have to remove the battery. but rather just press the 'power' button located on left of camcorder.
Old 08-10-2013, 09:12 PM
August1991's Avatar
I have used my PJ790V in various situations, and have noticed various "champagne problems" but I haven't had this specific "third world problem" of a lack of power.
IMV, a PJ790V is like a Mercedes 600, and so I'd look at user error first.
August1991 is offline
