Tethering a camcorder to a PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2013, 06:05 AM - Thread Starter
sacentre's Avatar
Can anyone please advise me.
I need to find a camcorder that can be tethered to a Windows pc so that
1. The camera can be controlled via Windows Movie Maker ie liveview appears on screen, recording can be stop/started etc
2. The recorded video files are streamed to the pc hard disc in real time.
Right now I can do this with a Panasonic NV-GS35GC either via the IEEE1394 (DV terminal) or via the USB port.
Unfortunately, this camera is obsolete and needs to be replaced.  Most camcorders have a USB port but usually this is only used for transerring files from the camera memory or recording media to the pc afterwards.  I have checked the current Canon offerings but none of them can do what my obsolete Panasonic can.
Can anyone suggest a make/model that can do 1 and 2 above.
Thanks in advance
Trevor
sacentre is offline
post #2 of 2 Old 11-09-2013, 11:38 AM
fishywishy's Avatar
Quoted: 17 Post(s)
you will probably need to stick with a minidv camcorder that has firewire. the other option is try a hd webcam
fishywishy is offline
Reply Camcorders
