Sony 4K Handycam FDR-AX100 thread - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 143Likes
post #3061 of 3779 Old 03-13-2015, 07:40 AM
jamieuk147's Avatar
Quoted: 69 Post(s)
is this card ok for the new update?
http://www.amazon.co.uk/SanDisk-Extr...words=UHS-I+U3
jamieuk147 is offline
post #3062 of 3779 Old 03-13-2015, 08:04 AM
bsprague's Avatar
Quoted: 495 Post(s)
Liked: 180
Originally Posted by Greenwavepaul View Post
Your link shows a SDHC card. The AX100 should only accept SDXC cards. Did you try that card in the AX100 at 100mbps?
I use it in a differnt camera that records at 100mbps, the Panasonic LX100. The SDXC version is here: http://www.bhphotovideo.com/c/produc...l/prm/alsVwDtl
I have and am using both.
bsprague is offline
post #3063 of 3779 Old 03-13-2015, 08:13 AM
Greenwavepaul's Avatar
Liked: 27
The sdxc version should work, it has good user-reviews and. I ordered one.
Greenwavepaul is offline
post #3064 of 3779 Old 03-13-2015, 08:15 AM
Liked: 27
in theory, yes, no doubt.
post #3065 of 3779 Old 03-13-2015, 10:51 AM
Eugene157's Avatar
Quoted: 231 Post(s)
Liked: 41
Originally Posted by jgwatt View Post
Hi Eugene
With the PD13 editor I see that under Profile name/quality, if you press the + key you can increase the average bitrate {under rate control} up to 200000 does that not cover the situation for 100mbps.
Maybe first we have to discover what the extra 40mbps will do for our video filming. Hopefully someone with know what to do will be able to help.
Good morning to all.
Yes, that should do the trick and glad to read that the PD13 update fixed your problems.
At the moment I have 7 64GB SDXC cards and like you will wait for reports.
My BR burner is only 2X, bought one of the first ones on the market and it works fine. Waiting to replace it with a new one that will do the UHD BD standard later in the year. And I hope that it will do UHD using conventional BR blanks like the ones I use (Optical Quantum) that cost less than $ 0.50 ea. A UHD format in principle similar to burning HD on standard DVD blanks.
If so, that format will likely be limited to 60 Mb.
I am surprised that there are no reports yet, posting it on YouTube would be useless because of their compression.
Eugene
Eugene157 is offline
post #3066 of 3779 Old 03-13-2015, 11:55 AM
AJInstitute's Avatar
Quoted: 79 Post(s)
I have used SDHC cards in the AX100, it just requires the card to be formatted in exFAT.
Of course, that would be a strategy for currently owned cards. If you're shopping for a new one, no reason not to buy SDXC as it will be exFAT by default.
AJInstitute is offline
post #3067 of 3779 Old 03-14-2015, 01:53 AM
jamieuk147's Avatar
Quoted: 69 Post(s)
With a new 128gb card. Can anyone ruffly workout how many minutes total recording I should get after the new update with 100bit recording.
Trying to workout if I need to go bigger. About 45 mins would do
post #3068 of 3779 Old 03-14-2015, 02:46 AM
jgwatt's Avatar
Quoted: 60 Post(s)
A 64gb card will give 1 hour 17 mins so double that.
I am wondering what the benefits are when going from 60mbps to 100mbps.
jgwatt is offline
post #3069 of 3779 Old 03-14-2015, 03:28 AM
jamieuk147's Avatar
Quoted: 69 Post(s)
Higher bitrate, better quality
Crazyanaconda likes this.
post #3070 of 3779 Old 03-14-2015, 06:52 AM
chenderson2's Avatar
Quoted: 81 Post(s)
Liked: 24
I have many sdxc and one sdhc cards, and they all will work if formated as exFAT at the old 60 speed. NONE will work at the new 100 speed. You have to have the new card with the uhs3 speed. When the camera is switched to the 100 speed, it displays for a short time a message telling you this, then it just shows that flashing sd card icon on the screen that indicates you have no usable card installed.
chenderson2 is offline
post #3071 of 3779 Old 03-14-2015, 06:57 AM
Quoted: 81 Post(s)
Liked: 24
Now I'm just waiting for someone to shoot some comparable footage using both the 60 and the 100 and tell us if they can see any difference. I don't know if posted examples would let us compare, since our computer screens aren't 4K.
We're losing about an hour's recording time with the faster speed and, if you read the instructions, it indicates that at the faster speed still shots are not permitted.
post #3072 of 3779 Old 03-14-2015, 08:15 AM
Ken Ross's Avatar
Quoted: 5700 Post(s)
Liked: 6062
Don't expect too much from the higher bitrate. If your expectations are set too high, you may be disappointed.
I've tried that experiment with other cameras and I was hard pressed to see a difference.
milosh9k likes this.
Ken Ross is offline
post #3073 of 3779 Old 03-14-2015, 09:31 AM
milosh9k's Avatar
Agree with that. It is hard to notice in the 60 mbps footage any artifacts, but once encoded in different format, e.g. H.264 60mbps VBR, there are plenty of them. I hope the encoder will find more info in the 100 mbps original to produce higher quality for the same output format H.264 60mbps VBR
milosh9k is offline
post #3074 of 3779 Old 03-14-2015, 12:29 PM
Liked: 2
Hi guys,
I have been using 3 of the 128gb PNY SDXC cards rated at 90mb/sec transfer rate. I just did the V 3.0 firmware update. I set my cam to the 100mb/sec rec rate and immediately started to film on it - no problems. I'm super stoked. Now for the long concert footage I shoot I am going to grab some 256gb PNYs on Amazon.
The 128gb cards are a steal at $55 Prime right now. The 256gb are a little pricey at $122. But, for 4+ hours of festival recording - I'm going to bite the bullet.
This cam rules!! Go Sony go - now the Vegas Video Pro 13 4K rendering canisters make sense in their mp4 and mxf 100 Mbps default settings.
Science! It works bitches
fluffyhead is offline
post #3075 of 3779 Old 03-14-2015, 03:46 PM
Quoted: 81 Post(s)
Liked: 24
Here is a comparison of the 2 speeds with the new firmware.
As Ken says, I can't tell any difference.
post #3076 of 3779 Old 03-14-2015, 04:58 PM
spyker1212's Avatar
Quoted: 105 Post(s)
try to crop/magnify the video frame to 1/8 the original screen.
thanks in advance
Crazyanaconda and milosh9k like this.
spyker1212 is offline
post #3077 of 3779 Old 03-14-2015, 07:54 PM
leamas's Avatar
Quoted: 146 Post(s)
Liked: 30
So, what is the cheapest 128 gb card in the EU that works fine with the 100 Mbps recording mode?
leamas is offline
post #3078 of 3779 Old 03-14-2015, 09:53 PM
2Turbofan's Avatar
Quoted: 120 Post(s)
Liked: 67
https://www.youtube.com/watch?v=L9BKraR83Zg
I agree. I do not see any difference with stationary shots when viewing footage up close on my 4K Samsung, but I do notice slightly smoother more detailed video in panning shots. Not sure why 100 mbps would improve this though. I will test further. One thing that is annoying is the pop up message telling you that photo mode is not available when switching to 100 mbps.
2Turbofan is offline
post #3079 of 3779 Old 03-15-2015, 08:33 AM
LenMiddx's Avatar
Quoted: 37 Post(s)
I've just had a look at it on my iMac screen (5K Retina) and, to be honest, I couldn't see any difference.
I think that I'll get just one compatible card and see if there really is an advantage in using 100Mbs.
Maybe something will show up in the editing stage e.g. better quality after up-sampling after stabilization or something.
Or maybe I'll just wait until somebody else does some testing.
Is there anything else in the release that's useful? (i.e. Like the HDMI feed not closing down when recording in 4K? ..... now THAT would be nice.)
LenMiddx is offline
post #3080 of 3779 Old 03-15-2015, 08:44 AM
Liked: 1
In an other forum have saw less wobble at 100bit and after saw the clip for the tenth time I agree with that
ugo1 is offline
post #3081 of 3779 Old 03-15-2015, 07:55 PM
leamas's Avatar
Quoted: 146 Post(s)
Liked: 30
Anybody using a Transcend u3 card in 100 Mbps mode? I need to order a card that I know that will surely work.
leamas is offline
post #3082 of 3779 Old 03-15-2015, 08:07 PM
Ken Ross's Avatar
Liked: 6062
In all honesty, this video is not the best. The entire video is not properly focused.
Ken Ross is offline
post #3083 of 3779 Old 03-15-2015, 08:16 PM
Quoted: 81 Post(s)
Liked: 24
That's the one I used.
post #3084 of 3779 Old 03-15-2015, 08:38 PM
Quoted: 81 Post(s)
Liked: 24
I didn't think it looked very good, but I was just in a hurry to check out the 2 speeds. I just checked, and it turns out the focus was set to manual, so that explains why it was not focused properly. Also, I noticed the stabilization was not set to active. The only thing I did after updating the firmware was to set the AE control.
I'm going on a trip Tuesday, so I can check it out more thoroughly.
post #3085 of 3779 Old 03-15-2015, 09:31 PM
P&Struefan's Avatar
Quoted: 214 Post(s)
Liked: 55
For those of you who may have just one UHS-I U1 card in your AX100 and are planning on getting more I think it's a no brainer to get only new U3 cards from one of the reliable brands and upgrade the firmware. And for those of you who, like me, have more than a handful of U1 cards lying around it's probably worth waiting to see if this 40Mbps difference in the IQ is worth ditching all the U1 cards and buying the newer U3 ones.
YouTube is not a good place to see such difference especially the likely minute difference, if any, as a result of encoding at a higher bit rate as the posted footage has to go through at least a generation of re-encoding/re-compression at lower bit rates than either 100Mbps and 60MMbps. Compression parameters used are also completely different.
P&Struefan is offline
post #3086 of 3779 Old 03-16-2015, 06:21 AM
Quoted: 81 Post(s)
Liked: 24
Is it just my imagination or are there quite a few additional menu settings on version 3. Maybe I just failed to notice them previously. I found in the tool bar a way to check the battery health/charge. There seems to be a whole section for flash settings ( I don't know if the firmware is used on more than one camera or if the flash settings are there just in case someone attaches an auxiliary flash.)
post #3087 of 3779 Old 03-16-2015, 08:56 AM
Liked: 0
Hey everyone, i am new here, and have a question about this camera, i have filmed fireworks with this cam and not satisfied yet, i have used manual focus on infinite, and used the fireworks scene, but some fireworks is a little bit blurry.
If i wanna use manual settings what should i do with iris (aperture), gain/iso and shutterspeed? Any tips? Thanks in advance
Greetings Rick.
Vuurwerkftw is offline
post #3088 of 3779 Old 03-16-2015, 08:59 AM
Liked: 0
Sorry for the quote, something went wrong there.
post #3089 of 3779 Old 03-16-2015, 05:00 PM
jgwatt's Avatar
Quoted: 60 Post(s)
I do know that the flash settings were always there, they are just not highlighted / usable until you attach a flash unit to the camera.
jgwatt is offline
post #3090 of 3779 Old 03-16-2015, 10:18 PM
Will Dylan's Avatar
Liked: 7
I have tried this sony sd card and it works http://www.bhphotovideo.com/c/produc...mory_card.html
Will Dylan is offline
Reply Camcorders
