Sony 4K Handycam FDR-AX100 thread - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 117Likes
post #3481 of 3485 Old 07-24-2015, 07:59 PM
Liked: 0
Fyi
Originally Posted by chenderson2 View Post
Yes that confused me, too. There is no setting called "brightness," so why Sony chose that work, I don't know. Anyway, within the menu system there is a place to set the front wheel to control Exposure values, so you can set the camera to under or overexpose by a certain amount. I usually set it to -.2 or -.5.
I found the place "within the menu system." It's in the Camera/Mic group and called AE Shift. The -.2 makes a noticeable difference. Thanks again.
shoot2kill is offline
post #3482 of 3485 Unread Yesterday, 09:57 AM
Eugene157's Avatar
Quoted: 194 Post(s)
Liked: 33
Yes, surprising difference. I use that setting almost permanently
Eugene
Eugene157 is offline
post #3483 of 3485 Unread Yesterday, 02:57 PM
spyker1212's Avatar
Quoted: 60 Post(s)
the ev -.2 or ev-.5 setting applies to outdoor only? or also indoor shot?
spyker1212 is offline
post #3484 of 3485 Unread Today, 05:08 AM
chenderson2's Avatar
Quoted: 67 Post(s)
Generally only outdoors.
chenderson2 is online now
post #3485 of 3485 Unread Today, 05:12 AM
Will Dylan's Avatar
Quoted: 14 Post(s)
Liked: 4
I would be happy if Ax100 firmware does not reset all the manual feature to auto in wifi playmemories mode.
Will Dylan is online now
Reply Camcorders
