PRODUCT ADVICE NEEDED :) - AVS Forum | Home Theater Discussions And Reviews
Old 04-22-2014, 10:43 AM - Thread Starter
btone's Avatar
Not tech-savvy here. Please offer specific suggestions :)
I am looking for a camcorder that will:
- accept at least 32G memory card/USB.
- hook up to LCD monitor for LIVE play-back (this is important, as we're recording, we would like to view it live simultaneously.)
- good audio.
- under $875 preferably.
Thank you!
btone is offline
Old 04-22-2014, 11:20 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
Take your pick. Most current camcorders use SD cards up to 64 Gb. The easiest choice is a 32Gb SDHC card, possibly Class 10 but Class 4 will work in most cases.
Pick a LCD with an HDMI input and again most camcorders will supply a HDMI output for playback or direct monitoring of the recording.
Good audio will be obtained using an external microphone close to the subject so a Mic input on the camera is desirable.
My choice Panasonic HC-V750.
Terfyn is offline
