Panasonic HC-V750 problem with Mic Input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-18-2014, 03:15 PM - Thread Starter
witekwitek's Avatar
Hi, I just got myself the V750 hoping to be able to use it with my Zoom H2n as an external mic.
However when I plug in headphone output from H2n to mic input in the camera there is a lot of distortion and noise.
Anyone has the same issue? I checked the same setup with similar camcorder from SONY and it worked great.
I suppose there is something wrong with mic powering circuit in this model. Any clues? Is this problem also in other camcorders from Panasonic?
witekwitek is offline
post #2 of 14 Old 05-18-2014, 05:31 PM
bsprague's Avatar
Quoted: 493 Post(s)
Liked: 180
bsprague is online now
post #3 of 14 Old 05-18-2014, 05:37 PM
Quoted: 88 Post(s)
Liked: 32
Consider using the Zoom untethered to the camcorder, then sync the audio in post with editing software:
http://www.youtube.com/results?search_type=search_videos&search_query=how+to+sync+audio+with+video&search_sort=relevance&search_category=0&page=
xfws is offline
post #4 of 14 Old 05-19-2014, 12:04 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
The output from the Zoom is at line level the 750 expects a mic input which is at a much lower level. The attenuator cable suggested in #2 should do the job.
Most people who use a Zoom or other recorder do as suggested in #3 and sync up in a video editor.
Terfyn is offline
post #5 of 14 Old 05-19-2014, 01:44 AM - Thread Starter
witekwitek's Avatar
@xfws I need to cut short on my editing time - that's why I needed a camera with mic input.
The attenuation cables look a little bit pricy. I will try using DIY stuff: http://www.epanorama.net/circuits/line_to_mic.html
especially the one with condenser removing the DC bias
However. This is first time I experience distortion like this and I'm afraid that Panasonic did not do a good job on this. If I can't get it to work I will return the camera and claim refund.
post #6 of 14 Old 05-19-2014, 03:00 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
This is not correct. The input is for microphones only and will need an attenuator if you want to put a line output into it. It is possible that some camcorders will accept a line output into the "mic" socket but you will have to look at the specs to find one. They will have a switchable attenuator installed.
The Panasonic HC-V750 mic input works well and does the job it is advertised to do. I use external mics on mine all the time without any problems. So if you want to use your Zoom instead of a normal mic then you will need to buy an attenuating cable. BroadcastAV in the UK supply these cables for Zoom to camcorder with and without a monitoring socket. IMO Panasonic did an excellent job and have produced a great camera, I expect it will become the last "standard" for HD filming before 4K takes over.
Terfyn is offline
post #7 of 14 Old 07-30-2014, 10:24 PM
Liked: 0
Headphone jack is a line level output. You need a line-to-mic level converter to make this work.
jfsfilms is offline
post #8 of 14 Old 07-30-2014, 10:54 PM
fishywishy's Avatar
Quoted: 17 Post(s)
if you have one end in the headphone jack and the other end in the mic input do you end up with no sound?
fishywishy is offline
post #9 of 14 Old 07-30-2014, 11:30 PM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
I have one of these cables, it connects between my Zoom H2 and my 750. I use the Zoom as a quality mic input.
The headphone to mic attenuator quoted in #2 works perfectly. It needs to be installed according to the markings on the cable.
The headphone out from the Zoom is for monitoring purposes and has its own volume control so between the Zoom volume and the 750 mic level control a good audio recording is possible. It should be monitored using the headphone out on the 750.
The Zoom can still record so it is possible to match the Zoom recording with the video audio for a quality audio track.
To claim that the problem is with the camera just shows the poor understanding by the OP. He was lucky not to damage his 750 by using a direct connection. So instead of doing what he suggests in #5 he should buy a cable made by a company with experience in thus area.
Terfyn is offline
post #10 of 14 Old 08-25-2015, 02:23 PM
Liked: 0
V750 microphone question
I am recording coaching sessions and I need to get clear audio from both the person in front of the camera and the coach sitting behind the camera. The built-in microphone seems to be highly directional, so the voice from behind the camera is muffled. Are there any audio settings on the camera to change the microphone from directional to omni-directional? Thanks!
DanDiego92117 is offline
post #11 of 14 Old 08-25-2015, 04:19 PM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
You can change from "Zoom Mic" to "Stereo Mic", this may help. There is 5.1 surround sound which should pick up sound from the rear but you will need to process this in post production.
A better way is to use an external mixer (example Azden FMX-DSLR Portable Audio Mixer) to mix the signals from two mics into the camera. This will let you pick up the sound from the two sources without any problems.
Terfyn is offline
post #12 of 14 Old 08-26-2015, 09:37 AM
Ungermann's Avatar
Quoted: 516 Post(s)
Liked: 67
Would you claim refund if your gasoline-powered car did not accept diesel fuel?
Ungermann is online now
post #13 of 14 Old 08-26-2015, 11:18 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
I'm afraid you cannot blame Panasonic if you misuse their equipment. You CANNOT put a line input into a mic socket and expect it to work. All the information has been given to you in the above posts.
Terfyn is offline
post #14 of 14 Old 08-26-2015, 11:29 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
Further to what I said above, could the coach sit next to the student but out of camera shot?
Plus there are a number of "conference" mics which are omni-directional and would pick up both sides of the conversation.
Terfyn is offline
Reply Camcorders
