Help Please in DVD Burning - AVS Forum | Home Theater Discussions And Reviews
Old 05-25-2014, 12:26 AM - Thread Starter
pauli5500's Avatar
I used a Canon HF400 to shoot about 45 min of MP4@35mbfs. I used Corel Video Studio 6 to edit aand then I burned to a DVD with 8000 bit rate as MPEG2. Looks fine on computer but when I watch the DVD on my TV, vertical and horizontal straight lines get wavy if the camera moves at all. Should I have set the camera differently ( not too many options there) or should I have burned my DVD differently....or is there nothing that can be done to avoid this? I'ts just vacation stuff, not fast moving sports. Thanks.
pauli5500 is offline
Old 05-25-2014, 01:35 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
Try creating a file rather than burning straight to DVD. Then create your DVD from that file. Set the file rendering process to "Same as First Video Clip" Also try Enable 60p/50p Create the DVD from the file.
Also ask your question in the Corel VideoStudio Forum.
Terfyn is offline
Old 05-25-2014, 01:41 AM - Thread Starter
pauli5500's Avatar
Thanks for the reply..With the second burning, I did what you suggested and saw no difference than when I burned the first project from the timeline..
Old 05-25-2014, 01:46 AM
Terfyn's Avatar
Quoted: 119 Post(s)
Liked: 38
I wonder if it is a "rolling shutter" problem. Are you moving the camera too fast in a Pan. Look up Rolling Shutter in Wiki.
Terfyn is offline
Old 05-25-2014, 01:49 AM - Thread Starter
pauli5500's Avatar
Believe it or not, 40 years ago, I was a TV news photog shooting 16mm film so I have a good appreciation of a slow pan/tilt. I also get the wavy lines if the camera is still but the subject, such as a boat with many horizontal lines, moves.
