4K 60p Panasonic GH5 thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 316Likes
post #31 of 1058 Old 01-05-2017, 09:15 PM
Tom Roper's Avatar
Quoted: 279 Post(s)
Liked: 301
Originally Posted by markr041 View Post
Many editors and players cannot recognize the 10bit 4K H264 files from the GH5. Windows media Player cannot play them, VLS can. More importantly, I can vouch (and others have reported this) that the original H264 10bit files cannot be ingested in Davinci Resolve 12.5 and Magix Vegas Pro 14 - unrecognized. Others have reported success in Edius and some other editors. The 150 Mbps H264 60p 4K files (8bit) are fine, though difficult to decode.
I too can confirm, doesn't play, just the 60p ones. This is a problem. XAVC 10 bit 4:2:2 is fine so why not the Panny files?
HDR Colorist and Conversions
INTO THE CAVE OF WONDERS
Directed by MANUEL BENITO DE VALLE Produced by PEDRO PABLO FIGUEROA
Cast MANUEL ANGEL REINA, CLAUDIA GARROTE
LOVETHEFRAME STORIES, SOUNDTRACKS AND FILMS
Tom Roper is offline
post #32 of 1058 Old 01-05-2017, 10:03 PM
Mattias Burling's Avatar
Quoted: 427 Post(s)
Liked: 44
Dont panic guys, this happens so often its not even funny. Its just like when any new camera is released and its raw stills doesn't work with any editor. Its SOP for a new format.
The reason editors haven't got h265 yet is because almost no one bought the NX1 (I bought three anyway).
Patience
reanimator likes this.
Mattias Burling is offline
post #33 of 1058 Old 01-05-2017, 10:35 PM
Tom Roper's Avatar
Quoted: 279 Post(s)
Liked: 301
In this case it's not HEVC in the test files, but h.264 10 bit 4:2:2. The 8 bit 4:2:0 files are fine. Mark is exactly right.
post #34 of 1058 Old 01-05-2017, 11:01 PM
markr041's Avatar
Quoted: 938 Post(s)
Liked: 298
Originally Posted by bsprague View Post
The "test video" was this one: https://www.youtube.com/watch?v=3V77QaMZxmQ
The comment about Premier was at the bottom of the expanded notes.
Yes, the video is 60p, so it is not the problem one. All my editors and players can handle the 4K 60p 8bit clips. The problem is with the 24p and 30p 10bit 4:2:2 files only.
Tom Roper likes this.
markr041 is offline
post #35 of 1058 Old 01-06-2017, 07:16 AM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
Cinema 5D: Panasonic GH5 Hands-on – “6K” Anamorphic Video, 4K 60p, 180fps FHD
Technical Highlights of the Panasonic GH5:
  • Max Resolution: 4K/60p (Output Only)
  • Internal 4:2:2 – 10bit – Available April, 2017
  • 6K Anamorphic Video Mode (4:3) – Available Summer, 2017
  • Slowmotion (Variable Frame Rate): Max of 180fps/23.98 in FHD
  • Improved Auto Focus (0.05 sec AF, 9 FPS AF Burst)
  • Large HDMI (Type A/USB 3.1)
  • 3.2″ 1,620-dot Free Angle Monitor
  • 4K Hybrid Log Gamma (4K HDR Video) – Available Summer, 2017
  • SD Card Slot x2: UHS-II U3 (Vide grade 60)
  • No Recording Time Limit
  • Waveform Monitor Display
  • Separate Video Menu Mode
  • .MOV, MP4 (AAC, LPCM) AVCHD Progressive
  • H265 encoding for 60/50p
  • Selectable System Frequencies (59.94, 50.00, 24.00 Hz)
  • Splash, Dust, Freezeproof Upto -10 Degrees Celsius
  • Bluetooth
  • Weight: 2.0 lbs
  • Power: Same batteries as GH4
https://www.cinema5d.com/panasonic-g...0p-180fps-fhd/
jogiba is offline
post #36 of 1058 Old 01-06-2017, 08:33 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Patience
I have only one friend that works at Adobe. A significant chunk of his time is working on codec licensing. From what he says, it is a PITA and the playground is full of lawyers.
Cut and past from the Wikipedia topic of "High Efficiency Video Coding": "HEVC [H.265] is restricted by patents owned by various parties. Use of HEVC technologies requires the payment of royalties to licensors of HEVC patents, such as MPEG LA, HEVC Advance, and Technicolor SA. The licensing fees are many times higher than the fees for AVC [h.264]. The problematic licensing situation is one of the main reasons HEVC adoption has been very low on the web and is why some of the largest tech companies (Amazon, AMD, ARM, Cisco, Google, Intel, Microsoft, Mozilla, Netflix, NVIDIA and more) have joined the Alliance for Open Media, which aims to deploy the royalty-free alternative format AV1 in 2017."
bsprague is offline
post #37 of 1058 Old 01-06-2017, 10:14 AM
Tom Roper's Avatar
Quoted: 279 Post(s)
Liked: 301
Add to your comments that HEVC is a *highly* compressed format, with up to 250 GOP, 250 frames in a group that are built only from changes to the preceding frames. That's how compression works, by not encoding the full frame but just the frame to frame changes, a lot less data is used, extending recording time but not quality. All-I recording is also a form of compressed recording but records each frame fully and so uses lots more memory for the same recording time, wasteful in a static scene but better when there is motion.
To conclude, lower compression schemes like high bit-rate All-I h.264 are better for capturing quality than highly compressed codecs like HEVC which record only the difference between frames for a very long stream of frames.
The less compression, the better the quality.
post #38 of 1058 Old 01-06-2017, 10:16 AM
Ken Ross's Avatar
Quoted: 6657 Post(s)
Liked: 7331
At 2lbs, this must be the heaviest 4/3rds camera by far. It's reaching into the DSLR weight class. Aside from the IBIS, I'm sure heat dissipation was one of the factors in the weight increase.
Ken Ross is offline
post #39 of 1058 Old 01-06-2017, 10:19 AM
Tom Roper's Avatar
Quoted: 279 Post(s)
Liked: 301
That's why it is a pocket camera, because you have deep pockets!
Ken Ross, Ungermann and zmarty like this.
post #40 of 1058 Old 01-06-2017, 10:40 AM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
GH5 brochure link
https://drive.google.com/drive/folde...DRVN09vaW9jd2c
Spec showing H.265 only for 6K photo:
https://c1.staticflickr.com/1/353/32...aeb8cbbb_o.png
jogiba is offline
post #41 of 1058 Old 01-06-2017, 11:04 AM
Cloudstrewn's Avatar
Quoted: 38 Post(s)
Not being able to play the output seems to me a big plus - there will be no grounds for moaning about some aspect of the dynamic range, flesh tones, edge noise etc etc. therefore a much happier user.
Seriously though, those 10bit files read ok into After Effects and the free Virtualdub, but not into Avidemux.
Cloudstrewn is offline
post #42 of 1058 Old 01-06-2017, 01:26 PM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
Confirmed H.265 is in 6K photo only (@17:00).
6K photo sample:
http://lumixlounge.com/wp-content/up...2/P1000044.jpg
Ken Ross likes this.
jogiba is offline
post #43 of 1058 Old 01-07-2017, 08:45 PM
Tugela's Avatar
Quoted: 252 Post(s)
Liked: 120
From the limited amounts of real footage I have seen, this new camera looks like it is going to be an impressive competitor, at least for video. It looks very nice, especially on a 4K TV when you can appreciate it's full glory. Certainly a step up from the GH4 for sure.
No doubt Sony are going to up the ante with the mark III versions of their a7 cameras in 2017 as well. It is too bad Samsung left the market, otherwise they would probably have a kick ass new camera this year as well.
And Canon still continue to give us crud, lol.
Tugela is offline
post #44 of 1058 Old 01-08-2017, 12:47 AM
flintyplus's Avatar
Quoted: 225 Post(s)
Liked: 47
One thing i dont think has been mentioned is if the crop is the same as the GH4s.
flintyplus is offline
post #45 of 1058 Old 01-08-2017, 03:26 AM
Tugela's Avatar
Quoted: 252 Post(s)
Liked: 120
It does a full sensor read, so it does not crop like the GH4 apparently.
mpgxsvcd, markr041 and zmarty like this.
Tugela is offline
post #46 of 1058 Old 01-08-2017, 07:02 AM
Ken Ross's Avatar
Liked: 7331
I just got the Panasonic G85 and if this is any indication of where the GH5 is going, it will most assuredly be a winner. I'm very impressed with the footage out of the G85, and the IBIS coupled with the kit lens OIS, makes for some very impressive stabilization.
I like the way it rolls off highlights better than my Sony. Shooting a couple of snow scenes, the G85 was more impressive in how it handled the bright whites of the snow, clipping in a less obtrusive manner. Of course the kit lens, although very nice optically, is no low light champion.
Tom Roper and jogiba like this.
Ken Ross is offline
post #47 of 1058 Old 01-08-2017, 07:11 AM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
My favorite GH5 video so far :
jogiba is offline
post #48 of 1058 Old 01-08-2017, 08:22 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Originally Posted by jogiba View Post
My favorite GH5 video so far :........
Have you taken steps to survive between now and when your new camera comes? Three or four months of acute anticipation may take a toll!
bsprague is offline
post #49 of 1058 Old 01-08-2017, 08:47 AM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
Bill, between now and the GH5 shipping date of late March it's really ugly around here in NJ unless it snows .
my Jan 6th drone screenshot off the 4K UHD video
jogiba is offline
post #50 of 1058 Old 01-08-2017, 09:45 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Nice shot!
Maybe you'll have time to shop for a drone than can carry the GH5!
bsprague is offline
post #51 of 1058 Old 01-08-2017, 11:38 AM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
The Yuneec TORNADO H920 Multi-Rotor would work great with the GH5 up in the air or on the ground.
jogiba is offline
post #52 of 1058 Old 01-08-2017, 01:50 PM
Ken Ross's Avatar
Liked: 7331
Ooooo noooooo, I don't know about Joe, but no drone for my GH5!!!! As soon as that GH5 would be airborne, I'd need a porta potty.
jogiba, reanimator and zmarty like this.
Ken Ross is offline
post #53 of 1058 Old 01-08-2017, 02:45 PM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
No drone rides for my GH5, Ken.
GH5 Night ISO Test 200 to 12800
Ken Ross and termite like this.
jogiba is offline
post #54 of 1058 Old 01-09-2017, 05:24 PM
Tom Roper's Avatar
Quoted: 279 Post(s)
Liked: 301
Use the force Luke!
Pictured is Luke Neumann holding GH5 on gimbal. I guess we don't know if it's actually the GH5 on that gimbal, but I think it's fair to ask whether the video he produced relied on more than just Panasonic supplied IBIS to create the beautiful video images. He stated that IBIS likely the most exciting feature that customers want.
http://nofilmschool.com/2017/01/excl...-panasonic-gh5
post #55 of 1058 Old 01-15-2017, 02:37 PM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
At CES 2017, Newsshooter.com's Dan Chung gets some important details about the Panasonic GH5 for video shooting from Panasonic's Matt Frazer. At the same time he talks to filmmaker Griffin Hammond about his experiences in a month shooting with the new camera.
jogiba is offline
post #56 of 1058 Old 01-16-2017, 10:14 AM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
Joe (and others buying the GH5),
You should enjoy reading this:
Ten Differences Between the GH4 and GH5
bsprague is offline
post #57 of 1058 Old 01-16-2017, 11:04 AM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
Bill, that is why I pre-ordered it as soon as possible.
jogiba is offline
post #58 of 1058 Old 01-16-2017, 12:55 PM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
It is a good list of reasons to buy! I'm looking forward to seeing some of your footage taken with it. I know you have a good lens collection, but have you picked a favorite "all around" lens to match your new camera when it comes?
bsprague is offline
post #59 of 1058 Old 01-16-2017, 01:08 PM - Thread Starter
jogiba's Avatar
Quoted: 675 Post(s)
Liked: 361
Bill, my favorite is the Leica DG Nocticron 42.5mm f/1.2 ASPH Power OIS for fast action in all lighting conditions.
Screenshot from the youtube video:
jogiba is offline
post #60 of 1058 Old 01-16-2017, 01:23 PM
bsprague's Avatar
Quoted: 601 Post(s)
Liked: 221
https://www.youtube.com/watch?v=LRPfuEgHUhs
https://www.youtube.com/watch?v=8tXngVaLzUM
Joe,
I can see why. My initial exposure to photography was Nikon 35mm. Favorites were an f/1.4 50mm and a f/2.5 105mm. Crop factor calculations put that about in the middle. It would indeed be a wonderful lens. Do you know if it has or needs a firmware update for the GH5 version of "Dual IS"?
Now, with my Panasonic, I'm using a 14-140 a lot when I'm not trying to pretend to be a wildlife videographer with a 100-400.
Bill
bsprague is offline
Reply Camcorders
