New Sony HDR- HC3 Compact HDV 1080i Camcorder! - Page 13 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #361 of 372 Old 11-11-2006, 11:54 AM
mkerdman's Avatar
I apologize if this has been addressed, but, what is the consensus opinion as to the Sony HC3 (DV based) vs. the Sony SR1 (HDD based)?
Are most people in the know sticking with the HC3 or going with the SR1 for new purchases now?
Also, is the HC3 using an industry standard MPEG-2 codec that can be played and edited freely?
Alternatively, is there a 1-step standards conversion software for the SR-1 AVHD codec output that makes it playable and editable everywhere?
Thanks in advance!
Murray Kerdman
mkerdman is offline
post #362 of 372 Old 11-12-2006, 01:23 AM
timecop's Avatar
Yes, standard MPEG Transport stream, video format is 1440x1080i, MPEG2, audio is 320kbit mpeg2 audio.
SR1 puts H264 video and not sure what format audio into MPEG Transport Stream. You'd have to have something which understands editing H264 to make use of it. Not sure if somethign exists, unless some free/LE/demo version ships with a camera.
timecop is offline
post #363 of 372 Old 12-03-2006, 11:09 PM
angedc's Avatar
Can someone tell me how long it takes to download an hour of tape to the computer over the firewire connection (HDV->HDV)?
Also, is the required firewire connection 4-pin to 4-pin?
Andy
angedc is offline
post #364 of 372 Old 12-04-2006, 04:01 AM
blackbill's Avatar
Andy
1 hour.... it's real time... a 30 minute tape takes 30 minutes
4 to 4 will work... so will 4 to 6
blackbill is offline
post #365 of 372 Old 12-04-2006, 10:03 AM
angedc's Avatar
Thanks, Blackbill. I know I posted the same question in two forums and you answered in both, so sorry about that.
But I'm urgently trying to decide whether to buy this camera so I'm going to make the same error twice and post the same question here again:
I have scoured the manual for this other question and don't find the answer: can I record frmo the computer back to the camcorder? (So e.g. I could edit an HD movie, copy back to the camcorder, and show it on the TV that way). The Sony VEGAS manual talks about it in general as a feature of that editing software, but the HC3 manual doesn't seem to mention it, and in fact lists the things you can do with the HC3 and a computer, apparently exhaustively, and doesn't mention it.
Andy
angedc is offline
post #366 of 372 Old 12-04-2006, 10:35 AM
GodobeHD's Avatar
Yes, you can. I have done that myself with Vegas.
GodobeHD is offline
post #367 of 372 Old 12-04-2006, 10:37 AM
angedc's Avatar
Great, thanks!
I think that pretty much seals the deal for me as a temporary solution until I get either a media center computer for the TV room with HD capacity or an HD/Blu-Ray burner and player.
Andy
angedc is offline
post #368 of 372 Old 12-04-2006, 11:08 AM
GodobeHD's Avatar
if you are using HC3 as playback device that is a very expensive HD player! ;)
GodobeHD is offline
post #369 of 372 Old 12-04-2006, 11:27 AM
angedc's Avatar
Well, its about the same as say a Sony player, but with the added benefit of being a camera.
But serously, the main point is a camera of course. But it's nice to know I can play HD movies on the TV right away without having to come up with not only an HD player (at least half the cost of the camera, I guess, plus commitment to a format, and anyway I have tons of Sony points from my Sonycard so it would be a Sony Blu-ray player at $1000), and also not having to buy the HD burner yet. Another option is to use Pinnacle Studies to burn HD DVDs on regular media, but then I'd need to buy the HD player too, and with real money, not Sony points.
angedc is offline
post #370 of 372 Old 12-04-2006, 03:50 PM
blackbill's Avatar
If you want to save wear and tear on the cam ... then I used to (before i got the tosh) download, edit, and render as a mpeg2, (1440x1080, 25000k) and save it to the HDD. To view it I would play it with windvd through dvi connect to my tv.
post #371 of 372 Old 12-04-2006, 03:55 PM
angedc's Avatar
Good idea. But then I'd need a computer in my tv room, or perhaps some distributed video system that could handle HD, I guess (I do have an ethernet network that goes there). Maybe eventually, that's the way to go, but not right away for me, I think.
angedc is offline
post #372 of 372 Old 01-18-2007, 02:31 PM
dhittman's Avatar
test
dhittman is offline
Closed Thread Camcorders
