HDD Camcorder Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-18-2007, 03:54 PM - Thread Starter
Ragnarok's Avatar
Can you use a standard USB2.0 external HDD to "offload" the contents of your cameras HDD in the field without the use of a computer?
Friends don't let friends game in SD.
Ragnarok is offline
post #2 of 3 Old 02-19-2007, 05:02 AM
blackbill's Avatar
Not that I am aware of... unless the cam has the firmware to recognize an external HDD and the software to do the transfer.... you are stuck.
I hate to say it... but this is the problem with HDD cams. Sure a HDD holds more than tape, but once it's full....................
blackbill is offline
post #3 of 3 Old 03-14-2007, 06:47 AM
toonse's Avatar
Get an OTG device (like the Nexto OTG). It can plug directly into USB 2.0 devices and grab to it's HDD without an intermediary device.
And they are cheap.
toonse is offline
Reply Camcorders
