Need help backing up my videos from my DVD Camcorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-21-2007, 11:05 AM - Thread Starter
Azentium's Avatar
I used my DVD camcorder to film a trip I had previously, and now I want to back up the DVDs I used to record the trip on my hard drive as well as make copies of them, sadly I do not know how to do so. Suggestions?
BTW, I used DVD-R minidiscs to record the footage.
Azentium is offline
post #2 of 3 Old 03-16-2007, 03:44 PM
RScottyL's Avatar
I would probably go with Nero Burning Rom:
Nero Burning Rom
They do have trial versions, so you can test them before you buy. I use this to do cd copies or dvd copies.
Actually, I read more into the question, and see you want to copy it to the hard drive. There is free software called DVD Shrink which will do that. It could also burn to a dvd drive, but at that point, it usually likes to work with Nero.
RScottyL is offline
post #3 of 3 Old 03-18-2007, 08:22 AM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
you don't even need DVDShrink to do that.
1. plop your DVD-R to your PC drive
2. click "explore"
3. just click and drag the VIDEO_TS folder to whichever HDD location you want.
to do mini DVD-R to DVD-R copy, use any disc burning software (such as Nero 7) and click "CopyDVD". If you need a disc burning software, just PM me.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Reply Camcorders
