Canon HV10: PAL<->NTSC via firmware? - AVS Forum | Home Theater Discussions And Reviews
Old 03-04-2007, 07:57 PM - Thread Starter
fixed's Avatar
Long story short, I've ended up with a US-version NTSC Canon HV10 instead of a PAL one (sigh). I do plan on using it for some SD content.
I assume the difference is purely the firmware. Is there a way to convert the camera?
fixed is offline
Old 03-04-2007, 08:11 PM
DaveC E100's Avatar
I believe that the difference is a lot more than just firmware. There is absolutely no way that you will be able to convert it from NTSC to PAL standards.
Dave
DaveC E100 is offline
Old 03-06-2007, 09:14 AM
videobuff34's Avatar
Only Canon higher models have this upgarde facility, I believe
Hey, Free All Camera footage samples at http://www.listvideo.com
videobuff34 is offline
