Questions on low light - AVS Forum | Home Theater Discussions And Reviews
Old 03-13-2007, 11:01 AM - Thread Starter
smack's Avatar
Quoted: 16 Post(s)
When people say they get grainy or poor picture quality in low light what exactly are they considering to be low light?
If you are indoors and have lights on in a room is that considered low light thus reducing the PQ?
I would assume an school auditorium for a school play would be low light?
As I said in another post I am ready to pull the trigger on the HC7 and most of my vid's will be outside, but I do video the christmas / b-day parties too and want good quality video for that as well. So are shooting indoors and have lights on in the home is that enough? or does it depend on how much lighting you have? I don't want to set up movie studio lighting to record my kids b-day if you know what I mean.
smack is offline
Old 03-13-2007, 04:04 PM
DaveC E100's Avatar
When people say they get grainy or poor picture quality in low light what exactly are they considering to be low light? If you are indoors and have lights on in a room is that considered low light thus reducing the PQ?
YES!
Could be....some auditoriums are better lit than others.
It depends on how much light you have. Turn on all of your lights and see if that is enough. Some camcorders need more light than a normal household will have.
Dave
DaveC E100 is offline
Old 03-13-2007, 04:58 PM
AndyN's Avatar
Quoted: 23 Post(s)
Smack,
Great question. I'm a huge camcorder newbie and just bought the HC7. In daylight and outdoors its very very nice. At night overhead lighting and lamps on its ok. Lots of noise. The resolution is there as you can see the details but there is a haze of grain over the picture. The more lights I turn on the better. Since my 15 day return period ends before the HV20 releases I'm kind of "stuck". But I'm not sure how much better the Hv20 will be in low light. The HC7 is a good camera but definitely try it before you buy it. Nice but my expectations were too high I think.
AndyN is offline
Old 03-14-2007, 04:09 AM
blackbill's Avatar
The HV20 won't be a lot better... if any at all. HD cams in general need quite a bit of light, and that's life. If the lighting in your home is not bright then you will have to consider a lamp for your cam.
In places where I do a lot of shooting, I have actually increased the lighting. I have DAYLIGHT fluorescent bulbs in the basement (gives beautiful indoor shots) and I have a 500 watt hal. floor lamp for the living room.
blackbill is offline
