Camcorder HV20 DVDs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-18-2007, 04:02 PM - Thread Starter
J.Douglas's Avatar
Guys,
Believe it or not, I'm a bit new to the camcorder thing. If I buy a Canon HV20 (or other HDD camcorder) and want to record in high definition on the tapes, then transfer it to DVD using my computer, what do I need to have or do to watch those tapes (assuming I already have the high-definition tv)?
A regular dvd player?
An upconverting dvd player?
A high definition dvd player?
Does it matter at what bit rate(?) I transfer to DVD?
thanks
J.Douglas is offline
post #2 of 10 Old 04-18-2007, 09:35 PM
paintit77's Avatar
Step 1.
Go buy an HD-DVD Player from Toshiba. I would suggest the XA2 or HDA2.
Step 2. Read this guide! http://www.avsforum.com/avs-vb/showthread.php?t=705146
Step 3. Get the free CapDVHS to get the HDV off your camcorder.
http://www.videohelp.com/tools?tool=CapDVHS
Buy VideoRedo
http://www.videoredo.com/
and buy Ulead Movie Studio 6.
http://www.ulead.com/runme.htm
Step 4. Burn HD-DVD onto DVD-R (only -R Disks)
Step 5. Watch your HDV movies on your HD-DVD player!
I have close to 60 Movies on DVD that are in HD Glory playing on my HD-DVD player! It is amazing and you will love it!
paintit77 is offline
post #3 of 10 Old 04-19-2007, 06:04 AM
xue891's Avatar
How many minutes can you fit on each DVD-R disk?
xue891 is offline
post #4 of 10 Old 04-19-2007, 10:13 AM
GodobeHD's Avatar
its roughly 23min of HDV on a 4.7GB DVD-R.
GodobeHD is offline
post #5 of 10 Old 04-24-2007, 01:36 PM
Givmeabrek's Avatar
You could also skip about 5 or 6 of those steps (and they will take a few hours with a very fast PC) and get a DVD based camcorder like a Sony UX7. Record your video, pull out the DVD and stick it in your PS3 or Blu Ray player. Presto, high definition. If you want to finalize the DVD to add menu's it will take about 2 minutes in the camera. Couldn't be any easier. The quality is super.
Givmeabrek is offline
post #6 of 10 Old 04-24-2007, 04:09 PM
Ragnarok's Avatar
Question: Could the HD footage on the DVD be played in someone's PC without having an HD-DVD or BD player? I'm concerned that most of my family doesn't own an HD-DVD/BR player and thus won't have ANY way of watching the footage I record.
Question: Could the HD footage burnt to the DVD be played on the PS3 in full resolution?
Friends don't let friends game in SD.
Ragnarok is offline
post #7 of 10 Old 04-24-2007, 05:09 PM
Blasst's Avatar
Quoted: 66 Post(s)
Liked: 64
Originally Posted by paintit77 View Post
Step 1.
Buy VideoRedo
You can use just MF6+, and it will do it all for you. I just used it last night, and was able to skip using MF5, and Nero 7. Easier than before ,for me, only using one program, to import and burn HDV to DVD.
Blasst is online now
post #8 of 10 Old 04-24-2007, 05:51 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Givmeabrek, give ME a break.
1. finalization is needed for guaranteed player compatibility and to ensure no other material can be accidentally recorded on the disc.
2. finalization can take up to 40 minutes (this is based on what I personally witnessed).
3. the quality may be super but ANY HDV camcorder (albeit tape based) is MORE super than any current AVCHD camcorder. You can even see the difference on a 32" 16:9 HDTV from 8 feet away.
4. enough with the posting of the same info in multiple threads
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #9 of 10 Old 04-24-2007, 05:58 PM
mansulta's Avatar
Actually, if a disc is full of recordings, it shouldn't take more than a few minutes to finalize. When the disc isn't full, it takes longer. The UX7 manual says that it can take up to several HOURS. To quote givemeabreak, "Ouch..."
Yeah.
mansulta is offline
post #10 of 10 Old 04-25-2007, 01:17 PM
GodobeHD's Avatar
For a fact the DVD does NOT play in any stand alone BluRay player. For a year since Sony released BD players and DVD based HD camcorders the myth of their compatibilty has been widely assumed among Sony fans. The truth is that just because Sony says BD's specs includes AVCHD doesn't mean AVCHD DVD can play in any standard BD player.
GodobeHD is offline
Reply Camcorders
