HV20 Exposure for Time Lapse - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-20-2007, 07:54 PM - Thread Starter
flyingscott's Avatar
I just shot some video yesterday with the intention of speeding it up in post to achieve a time lapse effect.
Click here to see the sample (~25mb)
I'm close to getting what I wanted, but had a question about the exposure on the HV20. I shot the clip in shutter priority at 1/24 (I think 12 would have given me even more of the blur effect I wanted). Now, if I manually adjust my exposure, does that change my shutter speed. I don't see the shutter speed change when I up the exposure, but I loose control of the shutter... If I go back into shutter priority mode, I loose my locked exposure. Also, when I am adjusting the exposure, is it just opening my aperture?
I realize these may be obvious questions, but the LCD display on the HV20 is not always telling as to what is being effected by the exposure +/-.
Scott
flyingscott is offline
post #2 of 3 Old 04-20-2007, 08:06 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Scott
1. If you lock the shutter speed, the exposure becomes variable. If you lock the exposure, the shutte speed wil be variable.
2. yes, exposure = aperture.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #3 of 3 Old 04-20-2007, 10:48 PM
mkaplan's Avatar
Yes, as David said.
If you wanted to control both aperture and shutter speed then you would need to be in full manual mode. Make sure you realize that if you did go manual and changed both to be different than what the camera would have chosen, you will probably be either over or under exposing your shots, The camera will move 1 stop up or down opposite to the shutter speed going up or down. If the correct exposure is 1/125 @ f4 then it is also correct if you select 1/250 @ F2.8. Moving 1 stop faster menas there is 1/2 the light coming in so you would need to open the aperture by that one stop to get the same overall exposure. In general, leaving the camera control the other is a good thing unless you are on purpose trying to over/under expose.
mkaplan is offline
Reply Camcorders
