HV20 HDMI Audio Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-22-2007, 06:48 AM - Thread Starter
docderwood's Avatar
I have an HV20 and Denon 4806 Receiver. I get no audio (but Video is fine) from the hdmi connection from the HV20. I called Canon..they had no suggestions. I then exchanged the camera...still no luck with a new HV20.
This should not be a configuration issue, I can unplug the HDMI plug from my tivo and plug it into the HV20 with the same result: Video but no audio.
Any ideas?
thx,
dj
docderwood is offline
post #2 of 4 Old 04-22-2007, 08:02 AM
flyingscott's Avatar
Have you tried to go directly into the TV via HDMI?
flyingscott is offline
post #3 of 4 Old 04-22-2007, 08:05 AM - Thread Starter
docderwood's Avatar
No...The TV only has DVI.
post #4 of 4 Old 04-22-2007, 09:06 AM
Golfer Guy's Avatar
Unfortunately, DVI only supports video and not audio. Using a HDMI to DVI only converter only sends through the video part of the HDMI signal.
At least your HV20 is fine!
Golfer Guy is offline
Reply Camcorders
