HV10 Firewire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-23-2007, 04:01 AM - Thread Starter
redmanfs's Avatar
I recently purchased a Canon HV10 camcorder. I am trying to download video from the tape to my Compaq nx9420 laptop; using a firewire cable. I am running windows professional vers2002 Service Pack 2. The laptop has a 4pin Firewire port.
I am trying to capture the video with Windows Movie Maker. When I use the "Capture from video Device" function it returns the following error message: "A video capture device was not detected. Verify that a device is turned on and connected properly; and then try again."
In one of the other forums I saw one of the members is using CapDVHS to capture the stream. This program regonise the HV 10 as "Microsoft AV/C Tape Subunit Device (Canon HV10#1). The problem with this program is that after this I still need to convert the format using a third party program.
Can you please assist me with the issue of Windows Movie Maker not detecting my HV10.
redmanfs is offline
post #2 of 5 Old 04-23-2007, 11:17 AM
josephcoatar's Avatar
i recommend using a program called sony vegas 7.0, i upload video from my hv10 all the time with it, and its never given me trouble, once the video is in your computer i recommend you play it using a program called VLC player, vegas also works like a charm if you want to transfer edited HDV footage back to the hv10, the results are always smooth and error-free
josephcoatar is offline
post #3 of 5 Old 04-23-2007, 12:43 PM
CountryJoe's Avatar
I am looking around for a copy of this. Do you have any suggestions for sellers? Also, what are the specs on your PC that you are processing the HV20 output? Thanks, Joe
CountryJoe is offline
post #4 of 5 Old 04-24-2007, 06:28 AM
i obtained my copy of vegas through *ahem* questionable means, but i've seen it for sale at best buy, circuit city, and of course amazon.com, again i want to point out i'm using a hv10, NOT the hv20, i could have waited to buy the hv20 but i noticed its optical array was identical to the hv10, i didn't need 24p or hdmi, so i just went ahead with the hv10 (i brought the last one from crutchfield.com BTW), as for my pc it's just your typical run of the mill 2005 windows xp, with a 3.0ghz intel pentium 4 processor, it had 512mb of ram, but just to be safe i went ahead and added another gig of memory to handle the HDV footage smoothly
post #5 of 5 Old 04-25-2007, 11:19 AM
paintit77's Avatar
I would use CapDVHS which is a free program to get it off your camera.
Here is a link:
http://www.videohelp.com/tools/CapDVHS
paintit77 is offline
Reply Camcorders
