Will the HV20 do the job for me? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 04-26-2007, 06:21 PM
scsz's Avatar
David, thank you for the reply. I guess with the added resolution of HD vs SD a better quality less is needed. Does the Canon one allow for full zoom through?
Car Videos from Southern California
www.socalspeedzone.com
www.speedandmotion.com
scsz is offline
post #32 of 36 Old 04-26-2007, 06:31 PM
David Susilo's Avatar
Quoted: 636 Post(s)
Liked: 592
yes it does.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #33 of 36 Old 04-28-2007, 03:58 AM
tausifs's Avatar
Quoted: 12 Post(s)
Hi does anyone know if Sony Vegas will inverse telecine the 1080i/60Hz by detecting the tags , to 1080/24p ? Thanks.
tausifs is offline
post #34 of 36 Old 04-28-2007, 06:55 AM
bigbarney's Avatar
Quoted: 166 Post(s)
Liked: 61
Vegas will automatically remove pulldown provided the cam used FLAGS the pulldown.
If by chance you are referring to the HV20, vegas will not remove the pulldown because the HV20 lacks the ability to flag it.
bigbarney is offline
post #35 of 36 Old 04-29-2007, 12:05 AM
tausifs's Avatar
Quoted: 12 Post(s)
Thanks bigbarney. My mistake about HV20 and flags.
Are you aware of alternative software that will somehow detect the candence for the HV20 and do inverse telecine ? Thanks again.
tausifs is offline
post #36 of 36 Old 04-29-2007, 09:13 AM
bigbarney's Avatar
Quoted: 166 Post(s)
Liked: 61
Cineform HD link will capture and remove the pulldown for import to vegas. Google for it. I believe there is a 15 day free trial
Reply Camcorders
