AVCHD join files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-19-2007, 05:49 PM - Thread Starter
cmichel04's Avatar
Hello,
I have files from my camcorder (.mts files)
They can be imported in Pinnacle Studio 11 BUT if I export it does a re-encoding.
How exactly this can be done without re-encoding them (no point in re-encoding in the same format)
What software is there that can perform this mts join?
Thank you.
cmichel04 is offline
post #2 of 11 Old 06-19-2007, 06:19 PM
sbarrier's Avatar
What kind of camcorder do you have? I believe that the software that came with my Panasonic SD1 can join files together, although it is a pretty poor piece of software.
sbarrier is offline
post #3 of 11 Old 06-19-2007, 06:33 PM - Thread Starter
cmichel04's Avatar
I have a Sony HDR-SR7
The software that came with this camera can create AVCHD DVDs but does not join files.
Is your software available for download someplace?
post #4 of 11 Old 06-20-2007, 06:23 AM - Thread Starter
cmichel04's Avatar
I tried TSSplitter (freeware) that can perform MTS join.
http://www.ffprojects.net/tssplitter/tssplitter.htm
HOWEVER, it introduces a pause between sequences in the final file.
Did you guys tried another program?
post #5 of 11 Old 06-20-2007, 07:14 AM
sbarrier's Avatar
HDWriter is the app that came with the camera. It does allow merging of the various scenes. However, it appears that you can only burn it to a DVD, not save as a new file.
I downloaded the "Vista" version from here. Be warned, there isn't much to it and it may not work with your Sony camera.
sbarrier is offline
post #6 of 11 Old 06-20-2007, 07:56 AM - Thread Starter
cmichel04's Avatar
The Panasonic program is an update to the existing CD so it doesn't work.
Any solution that works?
post #7 of 11 Old 06-20-2007, 04:22 PM
sbarrier's Avatar
Sorry, I didn't realize that was only a "Vista" patch.
sbarrier is offline
post #8 of 11 Old 06-22-2007, 07:24 AM - Thread Starter
cmichel04's Avatar
Is there another program that can join MTS files? (no recompression)
post #9 of 11 Old 10-06-2008, 10:38 AM - Thread Starter
cmichel04's Avatar
Finally, there is a solution that works and does not re-encode MTS (M2TS) files
(THE FILES HAVE TO BE RENAMED FROM MTS TO M2TS)
tsMuxeR
http://www.videohelp.com/tools/tsMuxeR
Open the first file with the ADD button, the rest of the files with the APPEND button
And then save to m2ts and works perfectly.
post #10 of 11 Old 10-06-2008, 04:49 PM
kalak's Avatar
tsMuxeR
Be careful about A/V sync issue. If you start join a lot of clips, the later ones' audio can get terribly out of sync with tsMuxeR. Pixela, on the other hand, has no such issue.
kalak is offline
post #11 of 11 Old 05-21-2011, 11:01 AM
DRKK2020's Avatar
The tsMuxeR audio delay problem can be solved by using tsMuxer together with ea3to.
One first uses ea3to to join the audio portion of the mts files. One then uses tsMuxeR to join the video portion of the mts files and combine them with the output audio file from ea3to.
A more detailed description can be found in this website:
http://avchdvideos.blogspot.com/
DRKK2020 is offline
Reply Camcorders
