Panasonic HDC-SD9 Pre-release - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 01-11-2008, 11:23 AM - Thread Starter
rbouch8828's Avatar
Does anyone know what the size of the image sensors are? I can't find it on any of the sites that have reported on it?
rbouch8828 is offline
post #2 of 44 Old 01-11-2008, 01:27 PM
shaggnasty's Avatar
shaggnasty is offline
post #3 of 44 Old 01-11-2008, 01:45 PM - Thread Starter
rbouch8828's Avatar
Originally Posted by shaggnasty View Post
1/6", according to this...
http://www.camcorderinfo.com/content...-HS9-34030.htm
Thanks for the info. I had hoped they were 1/3", but I guess that would have meant a bigger camera. I am looking forward to test results.
post #4 of 44 Old 01-20-2008, 06:54 AM
Mayhemm's Avatar
Panasonic kind of dropped the ball with this camcorder. I give them props for the added features (1080p@17Mbps, Face-detection, 5.1 Mic, and Advanced O.I.S.) but they did three things in the usability/connectivity department that may have lost them my business.
1) Moving the joystick from the back of the camcorder to the LCD cavity on the left. No more one-handed operation (if that's important to you).
2) Hiding the HDMI and AC connector behind the battery. You have to remove the battery to access them.
3) Making the HDMI connection a mini. Now I have to go and buy a new cable to carry around wherever I go because nobody else will have one.
If they would have left these things alone, it would have been very near perfect (IMO, of course). Respect minus, Panasonic.
Mayhemm is offline
post #5 of 44 Old 01-20-2008, 05:09 PM
talbain's Avatar
the only thing keeping this from being THE prosumer hd cam imo is the lack of mic and headset jacks. also, i'm not yet convinced that flash-exclusive recording is ready for primetime just yet. the cards are still a bit too expensive and too small to be practical for anything other than occasional use.
still, this is one sexy camcorder, and the price is right...
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
post #6 of 44 Old 01-20-2008, 07:58 PM - Thread Starter
rbouch8828's Avatar
I think that making the world's smallest HDTV CamCorder requires that connectors be moved or reduced in size.
I would like an audio in connector too, but I think for the first attempt at a 1080P camcorder in the smallest package out there, they have done a magnificent job. I just can't wait to see the test results.
Panasonic gets an A- from me, pending the video trials. Would have been an A+ if there had been an audio in connector.
post #7 of 44 Old 01-21-2008, 06:14 AM
Mayhemm's Avatar
I forgot about the lack of mic/headphone jacks. Panasonic got that wrong too. However, I actually think SDHC is pretty affordable (I've seen 8GB class 6 cards going from $50-$100). They're not very speedy compared to, say, the new UDMA compactflash cards (6MB/s Vs. 45MB/s) but they're essentially only handling 2 megapixel images, so 6MB/s should be enough for now. Plus there are 16GB and 32GB models debuting soon; perhaps a new speed class is coming with them. These new cards will probably shoot longer than the battery lasts.
You're right about the sacrifices that must be made for smaller size. I just wish they had opted to prioritize usability/connectivity over shrinking dimensions. I mean, the SD9 is smaller than the SD5, and even it was almost too small (for my big mitts, anyway)
Despite all my complaining, I'll still probably get one. Does anybody know if it has an A/V-IN for analog pass-through? I doubt it, but it would be nice to use it to transfer old stuff to my PC.
Mayhemm is offline
post #8 of 44 Old 01-22-2008, 05:54 AM - Thread Starter
rbouch8828's Avatar
post #9 of 44 Old 01-22-2008, 06:03 AM - Thread Starter
rbouch8828's Avatar
And here is another review from the UK: http://www.simplydv.co.uk/Reviews/pa...c_hdc-sd9.html
post #10 of 44 Old 01-22-2008, 01:05 PM
Ken Ross's Avatar
Quoted: 6595 Post(s)
Liked: 7301
17Mbps? Can anyone confirm this? The SD5 was only 13Mbps. I thought the upcoming Canon was the only show in town for 17Mbps. I tend to think the datarate is unchanged or these 'first look' reviews would have mentioned it. Going from 13-17 would have been a huge change.
Ken Ross is offline
post #11 of 44 Old 01-22-2008, 04:04 PM
Mayhemm's Avatar
I just got it from the "compression" section of CamcorderInfo's preview (the link is given in post #8). However, there may not be any truth to it since they incorrectly list the SD5 as recording at 15Mbps.
Mayhemm is offline
post #12 of 44 Old 01-22-2008, 04:44 PM
Ken Ross's Avatar
Liked: 7301
Wow! I didn't see that. But yes, the 5 only recorded at 13Mbps, so who knows if their info is correct. The British review mentioned nothing about it.
Ken Ross is offline
post #13 of 44 Old 01-22-2008, 06:28 PM - Thread Starter
rbouch8828's Avatar
Maybe the 17mbps figure is with the 5.1 audio added in.
post #14 of 44 Old 01-22-2008, 09:53 PM
Ear Whiskers's Avatar
The SD9 is my safety camera, with the Canon HF10/100 my main choice.
Is it safe to assume that the SD9 should, at least, have equal picture quality to that of the SD5?
I have the link to the Panasonic global site that confirms the 17Mbps bit rate... next post.
Ear Whiskers is offline
post #15 of 44 Old 01-22-2008, 09:54 PM
Ok, sorry about the double post but I needed 3 posts under belt before I could post the link:
http://panasonic.co.jp/pavc/global/v...fications.html
post #16 of 44 Old 01-23-2008, 10:14 AM
talbain's Avatar
the new panasonic is 17mbps, as are the new canons. the new sonys are 16mbps.
for me it's going to come down to the sd9, the canon hf10 or the sony sdr12. each to me has at least one significant flaw...
sd9 (pros) - amazing size. 17mbps. sd media. manual aperture/shutter control
sd9 (cons) - no built in storage. 16gb cards are expensive. no mic or headset jack...
hf10 (pros) - built in 16gb storage to use as safety or backup. sd media. manual aperture/shutter control
hf10 (cons) - 16gb cards are expensive
sr12 (pros) - built in 120gb hard drive. gorgeous large lcd screen. fantastic still capabilities
sr12 (cons) - proprietary memory stick format. no manual shutter/aperture controls. 16mbps vs. 17 for the others
very tough choices...
---Mr. Met---
talbain is offline
post #17 of 44 Old 01-23-2008, 12:02 PM
Ken Ross's Avatar
Liked: 7301
Wow! Very impressive! For me it will be either the Canon HF10 or this Panny. This little Panny has a lot of features that are really interesting. In the end though, picture quality will win out.
Ken Ross is offline
post #18 of 44 Old 01-23-2008, 12:07 PM
AnttiP's Avatar
Keep in mind that SD9 is 17 mbps VBR vs. SD5's 13 mbps CBR. Say SD9's bit rate range is app. 14-20 mbps vs. SD5's 13 mbps, that is over 50% increase at max. bit rate.
AnttiP is offline
post #19 of 44 Old 01-23-2008, 12:17 PM
For my needs, the HDD Sony is not on the list...
Maybe Sony will release the replacement for the CX7 before either the SD9 or Canon's HF begins shipping.
post #20 of 44 Old 01-23-2008, 01:06 PM
Ken Ross's Avatar
Liked: 7301
Not sure I'd interpret it that way. I would think it means that the max is 17mbps and can go below that for less demanding scenes.
Ken Ross is offline
post #21 of 44 Old 01-24-2008, 12:19 AM
AnttiP's Avatar
Look at the link below:
and table called Motion Picture Recording time
Recording time 2 hours at HA (max bit rate) for a 16 GB sdhc card
Doing the math:
16000*8/(3600*2)=17.8 mbps
Gives you THE AVERAGE bit rate
Atleast Sony has been using somewhat symmetrical bit rate aroud its average bit rate of 15 mbps.
ap
AnttiP is offline
post #22 of 44 Old 01-25-2008, 02:56 PM - Thread Starter
rbouch8828's Avatar
Not sure what the comment
is meant to say. Does anyone know what the audio component of the 17mbs number is and whether Sony includes audio in their number?
post #23 of 44 Old 02-02-2008, 08:38 PM - Thread Starter
rbouch8828's Avatar
Last year Panasonic introduced a "prosumer" version of their new HD consumer camera at NAB. Has anyone heard anything about plans to introduce a "prosumer" model of the HDC-SD9? Perhaps with mic input and headphone output?
post #24 of 44 Old 02-07-2008, 10:35 PM
johnswright's Avatar
What are the main differences with the sd5?
johnswright is offline
post #25 of 44 Old 02-10-2008, 05:07 AM - Thread Starter
rbouch8828's Avatar
SD9 has no hard drive.
post #26 of 44 Old 02-18-2008, 05:50 PM
herov's Avatar
Just purchased one via pre-order at Bestbuy. For the wife. Should meet all her needs.
herov is offline
post #27 of 44 Old 02-20-2008, 12:21 PM
hdspringer98's Avatar
I was just on the panny website and it appears one can actually order this camcorder now. I put it in my cart and it didn't say "backordered". Haven't ordered as I have a bunch of BB gift cards I'm going to use so once it hits bb I'll be checking it out.
Panasonic TC-P65VT60
Pioneer Elite AVR
Energy Connoisseur Series Speakers
SVS Sub
Xbox360
Panasonic Blu-ray
Apple TV3
hdspringer98 is offline
post #28 of 44 Old 02-20-2008, 01:01 PM
DaveKennett's Avatar
sd5 doesn't have a hard drive!
Biggest differences I remember:
24p
17Mb/s (13Mb/s max in sd5)
battery and card? access in the rear (bottom access in sd5 required removal from tripod)
joystick behind screen instead of thumb operated in the rear
I just got sd5. Not sure how workable joystick will be behind screen
Dave
DaveKennett is offline
post #29 of 44 Old 02-22-2008, 01:33 PM
budyl's Avatar
I just picked one up in Fullerton,CA CC store.
Good luck. Better hurry.
budyl is offline
post #30 of 44 Old 02-22-2008, 02:16 PM
herov's Avatar
there out? For real?
I ordered mine from BB.com hope it ships soon!
herov is offline
Reply Camcorders
