Optical Image Stabilization... bad for car-shots? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2008, 02:14 PM - Thread Starter
smash's Avatar
I'm having a huge problem finding camera(s) for a trip that I'm taking. I really liked the HV20 but I'm going to be mounting these to my car while driving and the secondary-lens for OIS causes a huge-issue with jittering.
So, between trying to find a camera with a MIC input, records to Tape or Flash in 1080i HD, and with digital NOT optical image-stabilization... I'm pretty much stuck aside from getting a camera that's like $3000.
Can anyone make another recommendation? I found the Sony HDR-HC5, which would have worked, but it doesn't have a MIC input. Damn it! And people say the HC7 has the same problem as the HV20 from Canon.
/me is really discouraged.
Check out my website... http://www.smashsworld.com/
smash is offline
post #2 of 3 Old 02-08-2008, 11:21 AM
Sean (Alabama)'s Avatar
Consider a Sony HC3 (or HC5) with this $20 mic input adapter:
http://www.bhphotovideo.com/c/produc...e_Adapter.html
Bored? Check out my blog: www.thelonglonghoneymoon.com
Sean (Alabama) is offline
post #3 of 3 Old 02-08-2008, 01:28 PM
scsz's Avatar
I tried my HV20 on three different mounts in my car (350Z) and never got any good results. My old SD cameras did much better (Panasonic GS250 and an old JVC). I have read some Sonys seem to do better with vibrations then the Canon.
I just got the Sanyo Xacti HD1000 and so far so good. It is flash based and does have a mic input. Here is a test clip http://sanyoxactiusers.com/forum/index.php?topic=12.0. I will be doing more tests in the coming weeks. I also have the Aiptek A-HD and it does a ok job considering the cost of it.
Car Videos from Southern California
www.socalspeedzone.com
www.speedandmotion.com
scsz is offline
Reply Camcorders
