Creating As Built wiring diagrams, Which software to use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-11-2008, 12:35 PM - Thread Starter
Nk1
Nk1's Avatar
Hello, I am looking for a good as built wiring diagram software solution.
Preferably Apple OSX but WindowsXP will do as well.
I currently am building some new racks and would like a solution for me being able to create graphing and wiring layouts (if one exists)
Any information is greatly appreciated On which software packages to look at.
Thanks so much!
Nk1 is offline
post #2 of 11 Old 07-11-2008, 05:17 PM
smoothtlk's Avatar
If you are a pro - D-Tools.
Otherwise - Visio, then PowerPoint
CEO
Allonis LLC
smoothtlk is offline
post #3 of 11 Old 07-11-2008, 05:54 PM
kevinw68's Avatar
NetZoom.
Works with Visio and gives you scale images of the products, front, back, and 3D. It also works with Middle Atlantic Rack tools.
kevinw68 is offline
post #4 of 11 Old 07-11-2008, 06:24 PM - Thread Starter
Nk1
Nk1's Avatar
Thanks! I will check those solutions out!
Thanks again
Nk1 is offline
post #5 of 11 Old 07-11-2008, 06:36 PM - Thread Starter
Nk1
Nk1's Avatar
D-tools looks amazing, unfortunatly it is out of my budget range for this project. I am looking for something that will allow me to create a wire list from rack components. Looks like D-tool might be the only all in one solution, Net zoom does look nice though, does anyone here use that?
Nk1 is offline
post #6 of 11 Old 07-11-2008, 07:53 PM
QQQ
QQQ's Avatar
I have not used it, but you might want to check out this, it is free.
http://www.avsnap.com/
QQQ is offline
post #7 of 11 Old 07-12-2008, 09:01 AM - Thread Starter
Nk1
Nk1's Avatar
WOW!!! going to try this out right now!!!! thanks a million
Nk1 is offline
post #8 of 11 Old 07-12-2008, 12:26 PM
QQQ
QQQ's Avatar
My pleasure. "Free" is always nice . I use D-Tools or I would give it a twirl. It looks pretty amazing for being free. It is not related to A/V documentation, but for those interested, another absolutely amazing free 3-D drawing tool is Google Sketch-Up.
QQQ is offline
post #9 of 11 Old 07-14-2008, 10:57 AM - Thread Starter
Nk1
Nk1's Avatar
Wow! Great find, Google sketchup looks great as well!
Nk1 is offline
post #10 of 11 Old 07-18-2008, 06:48 PM
mcmushx15's Avatar
AV Snap looks promising..can't wait to install it
Thanks for the link
mcmushx15 is offline
post #11 of 11 Old 07-20-2008, 08:08 AM
Speedskater's Avatar
Quoted: 20 Post(s)
I had a problem with AVSnap and I posted on the AVSnap Forum.
Then Jack telephoned me and using the "Meeting" feature of AVSnap to link to my PC he worked on my problem.
One of the signs of a skilled programmer is when he can navigate on someone else's computer with ease.
Kevin
Speedskater is offline
Reply Home Automation
