USB-UIRT API Documentation or Tipps - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By phelmers
post #1 of 2 Old 02-07-2009, 12:44 AM - Thread Starter
Pharados's Avatar
i would like to programm the api and find no documentation, i also tried to email USB-Uirt, but did not get a responce.
Pharados is offline
post #2 of 2 Old 02-08-2009, 01:36 PM
phelmers's Avatar
Hi Pharados:
I had the API stuff emailed to me several years ago. The supplied download link, www.usbuirt.com/api_example_code.zip still appears to work. I don't know if its still the latest but its worth a try... It has the DLL, a Help file documenting the DLL, and VB and C# sample programs.
Hope this helps...
- Peter
NaTeDoGG likes this.
phelmers is offline
Reply Home Automation
