Announcing MiCasa iPhone application for control of Insteon devices - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-08-2009, 08:20 PM - Thread Starter
art_h's Avatar
There's a new application available on the iPhone App store today called MiCasa. The first release of the app supports the SimpleHomeNet EZSrve and EZBridge controllers. The major advantage of MiCasa is that it does not require a dedicated PC or customized configuration files. It shows you the devices on your Insteon network in a simple list. It is simple, clean, and pretty fast. It even costs less than one switch or outlet!
There is also a free version coming soon that will allow control of a single Insteon device...
Here's the app description:
"MiCasa connects to a home automation gateway and allows for remote control of all switches, outlets, & dimmers on an insteon home network. Once configured with server information, MiCasa automatically configures itself and learns what things are available for it to control. No additional PC setup, expensive customized configurations, or additional software is required! The home automation gateways supported by release version 1.0 are only the SimpleHomeNet EZSrve (EZServe) and EZBridge home automation gateways. Supports most insteon switches, dimmers, and appliance modules with insteon device categories 0x01 & 0x02. MiCasa does not currently support more advanced insteon devices such as Thermostats, I/O controllers, sprinkler controllers, scenes or timers."
More features and controllers to be supported in future releases...
Visit WidgetalMedia dot com for more information.
Enjoy!
I am with Widgetal Media, the maker of MiCasa...
art_h is offline
post #2 of 3 Old 07-05-2009, 08:13 PM - Thread Starter
art_h's Avatar
MiCasa iPhone home automation control software version 1.1 is released on the iPhone App Store this weekend. It adds support for the SmartHome SmartLinc 2412N controller. Here is a list of all of the new features in 1.1:
New features in Release 1.1:
- Added support for SmartHome SmartLinc 2412N controllers
- Edit names in the device list
- Reorder devices in the list
- Ability to hide devices from the normal view
- Ability to place a SmartLinc in linking & unlinking mode
- Unresponsive devices turn red in the device list
- Some instabilities fixed
Supported Home Automation Controllers (ver 1.1):
- SmartHome SmartLinc 2412n
- SimpleHomeNet EZSrve and EZBridge
Features of MiCasa:
- Remotely turn on or off lights and control appliances!
- Realtime feedback shows you the status of devices.
- Enter server address and MiCasa automatically configures!
- Learns what devices are available for it to control.
- No additional PC, configuration, or software required!
- Supports most Insteon switches, dimmers, and appliance modules with insteon device categories 0x01 & 0x02.
JUST TO MAKE THINGS FUN - the first 5 people to enter one of the 5 free iTunes codes below will get a FREE copy of MiCasa! Save yourself $29.99. Once a code is redeemed, it is unavailable for anyone else to use... so hurry! Just log into iTunes and click on the "redeem" button, enter a code, then sync your phone... Please be courteous, if you do not have a SmartLinc or EZSrve, please don't waste a code!
6PFJ636PLYHE
7FN7ETJ63AFW
6XE49FK4MTFR
HL7KXHT64HTT
TA4PYE4FXTP3
Enjoy!
- Art
art_h is offline
post #3 of 3 Old 07-16-2009, 05:19 PM
leonowski's Avatar
hi art,
neat idea. I have a smartlinc controller but I am unable to get it to work.
How should the address be entered in the settings? My smartlinc has a username and password too.
leonowski is offline
Reply Home Automation
