Lutrons RadioRA2 - Page 46 - AVS | Home Theater Discussions And Reviews
 31Likes
post #1351 of 1357 Old 02-20-2015, 07:33 AM
Liked: 2
It's nice to hit a button on a Pico / tabletop keypad / iPhone Widget and turn the fan on, without getting up. It's nice to hit one button on a keypad / iPhone Widget and turn everything off in the room. It also looks nice on the wall, as Swancoat mentioned. I guess I am just too lazy... :-)
notek is offline
post #1352 of 1357 Old 02-20-2015, 03:56 PM
wkearney99's Avatar
Quoted: 144 Post(s)
Liked: 78
I have my "All Off" scenes set to include turning off the fans. I likewise have bedside keypads in the master bedroom configured to toggle them on/off (to one of the speeds).
I do not yet have my family room fan installed but can definitely see where being able to control it from multiple locations (large open space adjacent to kitchen) will come in handy.
I'd use them for bathroom fans but there's no 'simple' way to have a timer associated with them, like on the non-RA Lutron countdown fan timers. THOSE are great for bathrooms. They use the from side switch (dimmer adjustment on RA2 lights) to adjust the timer duration. I'd LOVE to have that kind of functionality with RA integration.
I plan on moving one of the fan controllers to a different spot as the wall only has a two gang box (and no room for more). I'll use the keypad for the fan speed & light, along with another dimmer for the ceiling recessed cans. Right now the fan light isn't switched (just the chain). I could move that dimmer somewhere else but I feel it'd be more useful to have a hybrid dimmer/keypad there instead (as there's no hybrid/fan device). I suspect they'd sell a lot of them if they made a fan/light combo unit.
wkearney99 is offline
post #1353 of 1357 Old Yesterday, 06:37 AM
CSO
CSO's Avatar
Thank you to those who replied about the ceiling fans. I will likely incorporate the frequently used ceiling fans into the RadioRa2 retrofit.
What about walk-in closets? I like the idea of occupancy sensors in walk-in closets, and automating closet lighting with RadioRa2 seems easy enough. However, I can achieve the objective for a lot lower cost using products from Lutron's Maestro line.
What is lost by relegating walk-in closet lighting to a non-RadioRa2 solution? Are there worthwhile benefits to having walk-in closet lighting on the whole house system?
CSO is offline
post #1354 of 1357 Old Yesterday, 10:06 AM
dgage's Avatar
Quoted: 735 Post(s)
Liked: 409
I don't think it's worth it. I use the Maestro occupancy sensor/switches for bathrooms, closet, laundry room, etc.
CSO and jautor like this.
dgage is offline
post #1355 of 1357 Old Yesterday, 10:24 AM
wkearney99's Avatar
Quoted: 144 Post(s)
Liked: 78
Given the overall cost, the addition of a dimmer and a motion sensor is pretty trivial. I find it helpful to have the ability to set a scheduled event to turn it and other lights off on a regular basis. With the motion sensor that's not 'necessary' since it can be programmed to turn it off on it's own. That and separating the sensor from the wall switch allows for being able to fine tune exactly where the motion will trigger it. In our master closet that would not have been convenient as there are two doors into it and the line of sight to both wall switch positions are blocked by cabinetry. A sensor on the ceiling is the only place that works.
post #1356 of 1357 Old Today, 05:30 AM
schalliol's Avatar
The only main RR2 advantage with RR2 in closets I is the ability to integrate the lights with an alarm system. You might want your closet lights to turn on if there's a burglar or the low lights if there's a fire. I don't currently have my system integrated to a panel.
I suppose I could see an "endgame" use as well of turning the lights on for a house showing with one button, but that's probably of trivial value.
schalliol is offline
post #1357 of 1357 Unread Today, 03:59 PM
spiwrx's Avatar
Quoted: 27 Post(s)
Liked: 24
Is it worth the expense to incorporate the ceiling fans into the RadioRa system? Do users find that they need remote control of their ceiling fans?
Or is it reasonable to save a little money and not incorporate the ceiling fans into the RadioRa2 system?
You have to look at how you use your fans now. If you use your fans a lot but rarely change speed, just use the RR2 Switch (you can change speed on the unit/chain directly). If you use them often and frequently change speed, definitely recommend the Speed control. I have the RR2 speed controls but mostly leave them on the same speed. I have a "catch-all" timeclock setting which shuts everything down at 2am, for us this works perfect because by then the fan is usually unnecessary. You may want something like that and set multiple times to gradually reduce speed, or exclude the fan. (~~~be sure the Fan Speed control is compatible with your fan, it works with most common fans but some of them now have proprietary controls and/or DC motors that may not be compatible~~~)
Sometimes my customers get bit by the bug and want to control everything, but the nice thing with RR2 is you can always add it later...
Paul W.
'Lutron Grafik Eye & Radio Ra Specialist - or anything Lutron'
Hanks Electrical Supply
www.hankselectric.net
FB Page
paul@hankselectric.net
spiwrx is online now
Reply Home Automation
