Lutrons RadioRA2 - Page 47 - AVS | Home Theater Discussions And Reviews
 34Likes
post #1381 of 1405 Old 03-12-2015, 07:03 PM
schalliol's Avatar
Quoted: 18 Post(s)
Paul is helping me out on this, and I assume he can help others who wonder about this. You buy the unit with the engraving (as opposed to the keypad send in for a button kit).
schalliol is offline
post #1382 of 1405 Old 03-25-2015, 09:01 AM
spiwrx's Avatar
Quoted: 29 Post(s)
Liked: 26
vcrx
A few random things:
  • Poking around in my "APP" it looks like they added support to directly operate the VCRX CCO's, previously I had created virtual keypads to trigger these.
  • I had opportunity to help program a small project and the customer had a "Windows" phone, someone has written and "APP" for RR2 in there but it's not very useful, and sent segmented commands, as in shutting off a room with 4 circuits, it shut them off in sequence instead of all at once. If you have a windows phone, I'm sorry but it was only $2 and it did offer some base level operations.
  • As described above, the 4Button Pico can be custom engraved with limited options, and the best utility for for the engraving is in the software as the current "engraving sheet" has fewer options. (Engraving is done at time of ordering and can take 2-3 weeks)
  • The 4 Button Pico comes in some variations, but it seems the 4th (bottom) button is reserved for "All Off" in all cases, making at best a 3 scene + All Off. Still a pretty clean unit.
  • I getting asked a lot about the Grafik T, be careful if you order these as they are available in both a wireless and RR2 versions (Similar to the Maestro RF and RR2).
If you haven't upgraded software in while, I'm at 8.2 and I haven't checked in a few weeks for a newer one.
Paul W.
'Lutron Grafik Eye & Radio Ra Specialist - or anything Lutron'
Hanks Electrical Supply
www.hankselectric.net
FB Page
paul@hankselectric.net
spiwrx is offline
post #1383 of 1405 Old 03-25-2015, 02:31 PM
dgage's Avatar
Quoted: 798 Post(s)
Liked: 436
Paul - I resent all of your remarks against "Windows" Phone...why the quotes? I like my phablet Lumia 1520 just fine thank you. Thanks for the info.
dgage is offline
post #1384 of 1405 Old 03-25-2015, 03:48 PM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
I feel like this has been asked before, but I can't find it now. What is the easiest way to integrate RR2 with a logitech harmony remote? Do I still need to run an IR emitter to my keypad and use a micro to change between scenes?
The Plains Theater Has Begun
J_P_A is online now
post #1385 of 1405 Old 03-26-2015, 08:19 AM
Swancoat's Avatar
Quoted: 32 Post(s)
If it's a regular keypad (as opposed to hybrid keypad), and you don't need all 6 buttons, there's a configuration with an IR window on the front.
Swancoat is offline
post #1386 of 1405 Old 03-26-2015, 08:27 AM
Swancoat's Avatar
Quoted: 32 Post(s)
[LIST][*]Poking around in my "APP" it looks like they added support to directly operate the VCRX CCO's, previously I had created virtual keypads to trigger these.
Hey Paul, regarding the VCRX CCOs, it appears you can control them directly from the iOS app if they are set to 'Sustained On'. If they are set for momentary actuation, they don't show up.
Another note on apps, I recently downloaded HomeSense from the AppStore. One one hand it's relatively similar to Lutron's app (and costs a similar $19.99) but it has two key improvements:
1: it has a summary of how many lights are on, and the list of rooms has an icon depicting if there are any light on in that particular room.
2: it has the ability to select up to 5 loads or devices that will show up in a control center widget. So for stuff you access a lot, you don't have to unlock your phone, start the app and find the device. Just turn the screen on and swipe down. (Yes, we've become that lazy).
Swancoat is offline
post #1387 of 1405 Old 03-26-2015, 09:22 AM
Neurorad's Avatar
Quoted: 31 Post(s)
Liked: 91
I've read that some Lutron keypads have IR receivers on the back as well. Not sure about RA2.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #1388 of 1405 Old 03-26-2015, 09:30 AM
Swancoat's Avatar
Quoted: 32 Post(s)
When I installed my last keypad I looked. There's a hole there for sure, but I'm not sure if it's a jack (doesn't really look like one) or just a place to put an emitter.
Swancoat is offline
post #1389 of 1405 Old 03-26-2015, 10:35 AM
dgage's Avatar
Quoted: 798 Post(s)
Liked: 436
Thanks for the info on HomeSense Swancoat. But I went to look for it in the AppStore on my iPad and couldn't find it. Is that the correct name or is it iPhone only? Thanks.
dgage is offline
post #1390 of 1405 Old 03-26-2015, 10:54 AM
spiwrx's Avatar
Quoted: 29 Post(s)
Liked: 26
The hole is there for the IR emitter("bugeye"). There is no connection, just stick the emitter over the hole. Never used it myself, or heard how well that method works, but that's the intention.
markrubin likes this.
Paul W.
FB Page
spiwrx is offline
post #1391 of 1405 Old 03-26-2015, 11:43 AM
Swancoat's Avatar
Quoted: 32 Post(s)
I THINK it's iphone only.
Swancoat is offline
post #1392 of 1405 Old 03-26-2015, 12:05 PM
dgage's Avatar
Quoted: 798 Post(s)
Liked: 436
That's what I was thinking. Thank you.
dgage is offline
post #1393 of 1405 Old 03-26-2015, 06:03 PM
Neurorad's Avatar
Quoted: 31 Post(s)
Liked: 91
I don't think it's widely publicised, because of the NEC requirement for rated emitters, in the junction box. Any tips on a finding them?
post #1394 of 1405 Old 03-26-2015, 08:21 PM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
Is there an IR receiver on the front of the keypad? If not, I'll likely be trying the emitter in the back. As far as I can tell, I don't really have any other option for integration with a harmony remote.
J_P_A is online now
post #1395 of 1405 Old 03-27-2015, 06:50 AM
spiwrx's Avatar
Quoted: 29 Post(s)
Liked: 26
Yes, the 5 button regular keypads (non-hybrid) have an IR option (eg: RRD-W5BRLIR-color). You sacrifice a button, or 2 but this gives you that IR window up front.
The back-end/base-unit is the same for all (non-hybrid) keypads, so this is also a option you can select upon engraving as well, even if it was not originally ordered as an IR version. You can apply the 5button IR cover/button kit to it.
PSA: As mentioned above, for this to be a NEC compliant installation, if the keypad is operating on 120vac, then all the wire in that box should be rated no less than 120vac, including the bugeye wire. Further, you can run the keypad on 48volts and we've even powered them on 24v. Lutron recommends 48.
Paul W.
FB Page
spiwrx is offline
post #1396 of 1405 Old 03-27-2015, 09:07 AM
Neurorad's Avatar
Quoted: 31 Post(s)
Liked: 91
I found several CL3 rated emitters using google
http://www.outdoorspeakerdepot.com/i...e-blaster.html
http://www.amazon.com/Receiver-Emitt.../dp/B003UKJR7E
I think you just attach the emitter to the back of the junction box.
spiwrx likes this.
post #1397 of 1405 Old 03-27-2015, 10:44 AM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
Excellent! Thanks for the links!
I'll get one ordered. I need to look at how much space I have in the box. I think I'll need an angled one. 90 degree might be preferred. The last time I looked at the back of the keypad, I remember thinking the IR eye was shrouded by the keypad housing.
Once I get the emitter wired up we'll see how well it works.
J_P_A is online now
post #1398 of 1405 Old 03-28-2015, 06:58 AM
schalliol's Avatar
Quoted: 18 Post(s)
I've used the Lutron Spacer System before that shows their IR blaster that comes with the SPS-5WCR. I have one of these IR blasters in my Lutron bin, but I don't know if you can buy them on their own.
post #1399 of 1405 Old 03-28-2015, 08:37 AM
Neurorad's Avatar
Quoted: 31 Post(s)
Liked: 91
Thanks, schalliol. That document shows how the IR blaster is inside the box, but the LV wires stay outside of the box. I don't see those Lutron Spacer IR blasters available on their own, either, using google.
That blaster is designed to affect all of the keypads/switches inside the junction box. I guess that's why they call it a blaster, and not an emitter.
post #1400 of 1405 Old Yesterday, 07:09 AM
spiwrx's Avatar
Quoted: 29 Post(s)
Liked: 26
Yes, Spacer & Spacer System is more or less obsolete (or at least they have priced it into obsolescence). The IR systems, including Maestro IR havesuccumb to the MRF2 / Pico, RF systems (and likely these to the Casetta). I don't remember the Blaster being sold separately, but I thought they came with 2 blasters, so there might, and probably is, some surplus out there somewhere.
The blasters were only necessary when mounting the keypad away from the dimmers. In most cases the Keypad was in the same box, making them unnecessary.
Paul W.
FB Page
spiwrx is offline
post #1401 of 1405 Old Yesterday, 08:37 AM
schalliol's Avatar
Quoted: 18 Post(s)
Yes, I actually bought my Spacer System gear from your company, perhaps almost 10 years ago.
This is a bit of a tangent, but because the system has a strong memories for me:
My understanding was that the SPS-5WCR did not have internal blasting capability (R stands for remote) so I used them to blast in the ganged location and one other location. I actually use the IR into a Xantech box to go further. It was fun to make these guys work, but it required a lot of work in a retrofit situation.
Sticker 1: Listed 6B38 (UL logo below) M43
Sticker 2: A449615 (part number?) "FOR USE WITH SPS-5WCR AND SPS-SERIES DIMMERS ONLY"
To be clear, there's no reason to do Spacer System anymore, but it was the big one for IR control. I have to say that there's probably a better way today than using IR for a RA2 install.
post #1402 of 1405 Old Yesterday, 10:02 AM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
I have a harmony one, and from the Logitech website it looks like it integrates with something called a Lutron Smart Bridge. Anyone have experience with one of these?
J_P_A is online now
post #1403 of 1405 Old Yesterday, 12:05 PM
jautor's Avatar
Quoted: 477 Post(s)
Liked: 453
That's the Lutron Caseta system... Not RA2.
jautor is offline
post #1404 of 1405 Old Yesterday, 01:33 PM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
I haven't been keeping up with this since I bought my dimmers and equipment several months ago (maybe a year by now), but I'm must getting around to installing everything. Is RA2 being phased out by Caseta? I'll be more than a little disappointed if my lighting equipment is already being phased out and I'm just now installing it in the first room of my house.
J_P_A is online now
post #1405 of 1405 Old Today, 04:37 AM
jkv
jkv's Avatar
Caseta is not meant to replace RA2, it is meant for single room solutions and/or small spaces. RA2 is the large space/whole-house solution...unless you have a need to make the jump to QS.
Riverside Cinemas
jkv is online now
Reply Home Automation
