Lutrons RadioRA2 - Page 57 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #1681 of 1691 Old 05-25-2016, 08:31 PM
bombertodd's Avatar
Quoted: 143 Post(s)
Liked: 70
I purchased these from Lowe's for my nine Halo can lights. They look nice and have worked great for a little over a year now. They dim pretty low too.
Klipsch RF-82II, RC-62II
2x Dayton Ultimax 12, Behringer iNUKE3000DSP
Denon 2113ci
bombertodd is offline
post #1682 of 1691 Old 05-26-2016, 05:55 AM
lbow's Avatar
Originally Posted by FlyingDiver View Post
My builder used the Halo H750ICAT, as I recall.
I thought H750ICAT was the led only. After thinking about it I will likely get edison base cans so that there is a larger selection and options with bulb + trim or led trim. Thanks
lbow is offline
post #1683 of 1691 Old 05-26-2016, 06:35 AM
FlyingDiver's Avatar
Quoted: 188 Post(s)
Liked: 51
I think you're right. Not sure where I got that number from. I think he actually used H7UICAT for the locations with 6" fixtures and H1499IC for the 4" fixtures.
FlyingDiver is offline
post #1684 of 1691 Old 05-30-2016, 04:32 PM
blkicevic's Avatar
Quoted: 53 Post(s)
Liked: 34
I just purchased/ordered 12 Serena Palette Translucent Roller Shades with the 4 group remote and a Smart Bridge Pro for Simple Control (roomie). I understand that all shades must be within a 30' radius of the smart bridge. I have 1 shade that is around 40' away. Will I need to add another bridge in order to communicate and use it with the app as well as Homekit and Alexa?
I do not condone what i do, but i will not deny myself the pleasure!
blkicevic is offline
post #1685 of 1691 Old 05-30-2016, 05:36 PM
Quoted: 188 Post(s)
Liked: 51
I'd just try it first. Lutron's 30' metric is very conservative. It'll probably work fine.
post #1686 of 1691 Old 05-30-2016, 06:37 PM
Quoted: 36 Post(s)
Liked: 7
It'll be fine in regular wood/drywall construction.
James Babin - System designer (http://www.myeasytek.com).
Like us on facebook!
JT Babin is offline
post #1687 of 1691 Old 05-31-2016, 05:36 AM
bpfunk's Avatar
Originally Posted by bpfunk View Post
Anyone have any tips to get the new connect found in essentials? I can see it on my dhcp table but just can't seem to find in design tab.
Ended up getting this to work the same way I had to do with the main repeater. Direct connect into the computer. Not sure why I always have this issue with lutron products...firewall I suppose. Works fine over network after activation.
bpfunk is online now
post #1688 of 1691 Old 06-01-2016, 12:23 PM
spiwrx's Avatar
Quoted: 52 Post(s)
Liked: 52
It was mentioned already, but 40' should be fine. Unfortunately you are stuck and one of the reasons to avoid Caseta for more than a room, studio or very small home/apt.condo. There is no Aux Repeater in Caseta and I don't believe
you can add an extra bridge.
On another note, if you are doing shades + Caseta we have another inconsistent lutron-ism. Standard Caseta Bridge only works with Serena RF, with no upgrade path. The Casta Pro Bridge can see both Serena + QS shades. If you plan on doing Shades + Caseta I would recommend the Pro-Bridge plus QS shades. That way if you get stuck you could replace the Caseta with RR2 or other QS system and not have to replace the shades also.
If I didn't mention it already in a previous rant, the Caseta is Cool & easy in function and if you like the style, great. But it was not meant to be a whole home system.
Paul W.
'Lutron Grafik Eye & Radio Ra Specialist - or anything Lutron'
Hanks Electrical Supply
www.hankselectric.net
FB Page
paul@hankselectric.net
spiwrx is offline
post #1689 of 1691 Old 06-08-2016, 09:38 PM
zoro's Avatar
Quoted: 212 Post(s)
Liked: 41
I have been promised by my HD dealer that they can integrate HD with Lutron but so far no help
zoro is offline
post #1690 of 1691 Old 06-09-2016, 05:19 AM
wkearney99's Avatar
Quoted: 293 Post(s)
Liked: 110
Is your HD dealer already a Lutron dealer? If so then they'd know there is no way to integrate the two. At least not without using something ($$$) from a 3rd party. Otherwise the dealer doesn't know what they're talking about, which is typical for salespeople...
I have both, RA2 and HD PowerView and, honestly, there's not much need to actually integrate them. Each has their strengths. HD's remote for shades is actually more versatile than Lutron's Pico units. But then Lutron has 'modes' for their automation schedules and PowerView does not offer that. I'd very much like to have a way to trigger more than one kind of mode, especially one that had the ability to randomize execution times for a security mode.
Neurorad likes this.
wkearney99 is offline
post #1691 of 1691 Old 06-23-2016, 05:02 PM
spiwrx's Avatar
Quoted: 52 Post(s)
Liked: 52
I had a new problem present it self with the remote mounting of some switches, I do not want to shed light on the exact use, because I don't agree with the installation and don't want to promote the purpose. However the solution open my eyes to something I thought might be useful to share if you haven't already figured it out.
The problem is this: We have 3 switches that need to come on in a certain sequence. If they do not, damage to the controlled equipment could occur (no fatal problem, specific injury or fire, but it would damage a few hundred dollars worth of equipment if operated incorrectly) So we can set up scenes on a keypad to handle the sequence, we can play with the timing and delay, so from a keypad it really reduces the risk to almost nothing. However, if they get in the APP they could independently control the switches and in the wrong order, wreck the equipment.
Well, turns out you can disable (dis-enable) the switches from being controlled in the APP from the Settings>Integration Settings > ID's tab. I haven't tested, but apparently, if not "enabled" it will be inoperable from the APP, or possibly excluded from the APP altogether. Again I haven't tested it, but if it removes it from the APP, you could really use it to clean up things up in the APP. Additionally, it would be nice if you could restrict devices by user, but it doesn't look likes that's possible or at least not obvious.
wkearney99 likes this.
Paul W.
FB Page
spiwrx is offline
Reply Home Automation
