Lutrons RadioRA2 - Page 60 - AVS Forum | Home Theater Discussions And Reviews
 88Likes
post #1771 of 1776 Old 11-22-2016, 11:57 PM
schalliol's Avatar
Quoted: 45 Post(s)
While I am not personally a fan of having two different rectangles in one wall plate like the first post, certainly an old iPhone or iPod Touch would be an easy and inexpensive way to have a dynamic keypad like available with HomeWorks QS using these boxes.
My experience is these phone or tablet interfaces really need to be used with guided access to suppress the dialogs that may come up on a mobile device from time to time. No one wants to see dialogs or errors on a wall.
While I am not a Bose fan, I can get behind the build Bose system. That's pretty nifty!
spiwrx likes this.
schalliol is offline
post #1772 of 1776 Old 11-23-2016, 11:45 AM
highnoon's Avatar
Can someone help with a RR2 system and trouble with the android app? The app will transmit the action but the status of the app is not updated.
Support from Lutron says I need a custom telnet login because I'm not getting proper 2 way communication with the main controller.
Can someone explain any of the whys and hows?
highnoon is offline
post #1773 of 1776 Old 12-01-2016, 04:18 PM
spiwrx's Avatar
Quoted: 62 Post(s)
Liked: 58
I might guess you're behind on some updates, however it's relatively simple to set up a user in the programming software. Not commonly needed anymore, however you can still do it.
What device or all are you having problems with?
Paul W.
'Lutron Grafik Eye & Radio Ra Specialist - or anything Lutron'
Hanks Electrical Supply
www.hankselectric.net
FB Page
paul@hankselectric.net
spiwrx is offline
post #1774 of 1776 Old 12-01-2016, 05:24 PM
highnoon's Avatar
Yes, I'm sure I am behind on updates.
About 3 years ago, I decided to install a RA2 system with an installer who handles several product lines including Lutron.
I thought about taking the classes to get access to the software and well... stuff happened. I have a system with a repeater and I thought there was some question whether I could even get the proper software to access my system - so i gave up!
So my system is a Lutron Ra2 with one main unit and one repeater.
I am having trouble with the android app getting feedback from the main system so that when I adjust a switch or light on the app -- the action occurs but nothing changes on the app.
So how do I get the software updated?
highnoon is offline
post #1775 of 1776 Old Yesterday, 10:05 AM
spiwrx's Avatar
Quoted: 62 Post(s)
Liked: 58
Best way is to take the free course online. If the original programmer didn't leave a copy of the program, you may have to re-program the entire system though. And after 3 year, depending on the number of devices, that might be better. Unfortunately, I doubt you may also know exactly which part numbers he installed where, which will complicate things, but that's merely just stumbling blocks the first time you try to activate. If you have to re-program you'll have to make you self familiar with how to "Factory default" (reset) each component.
I wouldn't really try to much else until you get everything updated.
Paul W.
FB Page
spiwrx is offline
post #1776 of 1776 Old Today, 05:52 AM
Super Moderator
markrubin's Avatar
Quoted: 991 Post(s)
Liked: 2174
I got Alexa working very nicely with RR2: I have 22 devices discovered including Nest thermostats and other commands through RTI program
for RR2, I use all 8 keypad commands and set up a Dot near the front door: so now when the dog needs to go out at night, I just say: Echo turn on outdoor (lights)
I am getting spoiled by using voice commands
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
"A system under which it takes three men to check what one is doing is not
control; it is systematic strangulation." - Admiral Hyman G. Rickover
markrubin is offline
Reply Home Automation
