Lutrons RadioRA2 - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 116Likes
post #1831 of 1838 Unread 02-15-2017, 09:29 AM
schalliol's Avatar
Quoted: 47 Post(s)
Thumbs down
In another round of ridiculousness, Lutron just confirmed there will be a gen 2 bridge that will enable the support for Siri/HomeKit (and I don't know what else, if anything). It was 10 months ago that the bridge started shipping.
I sure hope they do an upgrade program. This just embarassing product management.
wkearney99 and Neurorad like this.
schalliol is online now
post #1832 of 1838 Unread 02-15-2017, 12:38 PM
wkearney99's Avatar
Quoted: 324 Post(s)
Liked: 129
Agreed. They're just ruddlerless in the face of emerging tech.
schalliol likes this.
wkearney99 is online now
post #1833 of 1838 Unread 02-15-2017, 01:30 PM
Super Moderator
markrubin's Avatar
Quoted: 1048 Post(s)
Liked: 2300
quick question about Cree bulbs:
I am relamping my HT, replacing first gen LED bulbs that required one regular incandescent bulb to be left in each circuit to dim properly
the new bulbs are CREE Par 30 Long neck 40 degree flood sku 4966500836
I was able to get 5 of them from Home Depot: tested them (on a Lutron Grafik Eye) and they work fine
they are used for down lighting in recessed cathedral ceiling fixtures that vary from 9-15 feet high
now I go back to Home Depot to buy more and all they have are the same thing with 25 degree coverage: and the lighting manager claims they never carried the 40 degree bulbs
question is does it make a big difference if I have a mix of both 25 and 40 degree?
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #1834 of 1838 Unread 02-15-2017, 09:06 PM
schalliol's Avatar
Quoted: 47 Post(s)
Thanks for visiting our quaint thread, man, that's an awesome number of posts…
I'm not sure you'd want to mix and match them. Maybe if you can put them on each end of a room that could work, but 25 to 40 degrees is a big swing.
markrubin likes this.
post #1835 of 1838 Unread 02-18-2017, 04:04 PM
smoothtlk's Avatar
MarkRubin,
Check into these so that all of your lights can be same LED:
http://www.automatedoutlet.com/product-p/ilr-10k.htm
smoothtlk is offline
post #1836 of 1838 Unread Today, 09:17 PM
Quoted: 62 Post(s)
Liked: 5
I highly recommend the 2GIG GC3 if anyone is in the market. It's beautiful, integrates well with Lutron RR2 (and Caseta), features Z-Wave PLUS for other automation, has WiFi to be unlocked in the future, has everything in one package so you only have to run power, supports 2-Way Voice etc. At my house I put in garage door opener controllers and from the same app (or Apple Watch app) I can change Lutron settings, open or close garage doors, arm the system etc.
I liked it so much I decided to become an alarm.com dealer and 2GIG installer. Happy to help anyone. Self monitoring is possible cheaply.
this looks like giving screen
Ziba Ji is online now
post #1837 of 1838 Unread Today, 09:31 PM
schalliol's Avatar
Quoted: 47 Post(s)
I'm not sure I understand. Sorry if I'm missing it.
post #1838 of 1838 Unread Today, 09:32 PM
schalliol's Avatar
Quoted: 47 Post(s)
BTW 11.0 is out with support for HomeKit on the not available Connect Bridge 2. It also supports loopback protection in this build
Reply Home Automation
