Control4 speaker point offline - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-06-2010, 10:39 AM - Thread Starter
dcaulwell's Avatar
I have a very simple COntrol4 system at the moment. Media controller, wall mount wireless LCD keypad, wireless remote and one speaker point.
I just added the LCD keypad and now the speaker point won't come on line. I FINALLY got it to identify via the front button. It shows an IP address but shows offline and no link light on the front of the unit. ANY ideas?
dcaulwell is offline
post #2 of 13 Old 01-07-2010, 01:54 PM
HeGo's Avatar
Some questions:
- If you disconnect the LCD keypad the speaker points gets online?
- Are you using ethernet or Wi-Fi? Ethernet is better than Wi-Fi, at least for problem checking;
- Fixed IP or DHCP? Fixed is better as well;
Try resetting the speaker point by pressing the front button for approximately 12 sec.
Ultimately, could try resetting it to factory default: just press the front button for 30 sec, until all 3 lights come on and let go. However in this case you will have to reinstall it into your project.
Helio Gomes da Silva Jr
helio@pobox.com
HeGo is offline
post #3 of 13 Old 01-07-2010, 02:12 PM - Thread Starter
dcaulwell's Avatar
Originally Posted by HeGo View Post
Some questions:
I haven't physically disconnected power but will try disconnecting it from the project
ETHERNET speaker point
its terrible but don't know how to do that- I heard that may be the issue
Try resetting the speaker point by pressing the front button for approximately 12 sec. tried that to no avail- did not reset- opened it up and found a reset button
thanks for the help!!
post #4 of 13 Old 01-07-2010, 03:07 PM - Thread Starter
dcaulwell's Avatar
the thing that annoys me most is the way this gear identifies- push the button on the front and it should be seen and happy- but that is not happening now with the speaker point. Maybe took a power hit?- can I assign it an IP address?
post #5 of 13 Old 01-08-2010, 07:02 AM
HeGo's Avatar
The best thing would be:
  • Using Composer Tools/Network Status write down the IP addresses of all the devices in your project;
  • Turn off the LCD keypad;
  • Refresh Navigator;
  • Try to configure the speaker point with fixed IP address. Follows the manual. Make sure there are no IP conflicts;
  • After confirming the speaker point is working nicely, turn on the LCD keypad;
  • Refresh again.
Hope it helps.
SpeakerPoint.pdf 497.5693359375k . file
helio@pobox.com
HeGo is offline
post #6 of 13 Old 01-08-2010, 02:42 PM - Thread Starter
dcaulwell's Avatar
Thanks so much for the reply- let me give it a shot--- has to be an IP issue
post #7 of 13 Old 01-17-2010, 02:15 PM - Thread Starter
dcaulwell's Avatar
Negative - same issue- it will identify and then drop off the Earth. Maybe it did not update with the rest of the system? Would that cause it not to talk?
How can I reset the media controller to factory? maybe start over and try again?
I can ping the IP address that the speaker point comes up with and it returns normally.
post #8 of 13 Old 01-18-2010, 05:36 AM
HeGo's Avatar
As I said earlier, to reset it to factory default just press the front button for 30 sec, until all 3 lights come on and let go.
helio@pobox.com
HeGo is offline
post #9 of 13 Old 01-18-2010, 08:25 AM - Thread Starter
dcaulwell's Avatar
reset the media controller is what I mean.- the main controller on the system- Maybe bring that back down in composer releases. Maybe it is running too high a composer to talk to the speaker point??
Dunno- its a theory
post #10 of 13 Old 01-18-2010, 10:54 AM
HeGo's Avatar
Sorry, I don't know how to reset the media adapter. Try looking in www.c4forums.com.
helio@pobox.com
HeGo is offline
post #11 of 13 Old 08-04-2010, 02:23 AM
neildilgee's Avatar
I've got the same problem here. Did you eventualy fix it? And how?
neildilgee is offline
post #12 of 13 Old 08-04-2010, 07:40 AM
HeGo's Avatar
Actually it was not my problem, it was dcaulwell's. If you tried everything posted here, especially posts 2 and 5, I can't help any further.
Sorry.
helio@pobox.com
HeGo is offline
post #13 of 13 Old 10-06-2010, 10:27 PM
swoop19's Avatar
If you are familiar with Composer, you can check to make sure the firmware and software are both up to date. My experience with Control4 leads to me to believe it is a network related problem. What do you have it wired into? Router or switch? I am assuming it is wired. Are you using Composer Pro? If so, what software version?
swoop19 is offline
Reply Home Automation
