Elk M1 to Denon AVR - AVS Forum | Home Theater Discussions And Reviews
Old 01-21-2010, 12:10 PM - Thread Starter
rajah9's Avatar
I have a Denon AVR-4308CI. This model allows me to send commands to it over TCP port 23.
I have an Elk M1 Gold and an M1XEP interface. I have set my Netgear router to assign a static IP address for the Denon.
Is it possible to get Elk RP to send a string like PWON (Meaning "main PoWer ON") to a specific address like 192.168.0.96? I would like to wake to music, and issue the Power On command at, say, 6:30. (The Denon with the in-ceiling speakers would be a lot better than the current AM/FM clock radio.) The Denon also lacks a sleep feature, and I would like it to turn off 30 minutes after a task ("Good Night") is executed. Two-way RS-232 is not really needed for these tasks, and I will only be using a handful of commands.
Thanks for your help.
rajah9 is offline
Old 01-21-2010, 03:07 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Thought that question sounded familiar, saw it at cocoontech.
I would think it would be easier to control the 4308 using the serial interface, from the Elk, but I really don't know.
This document details the M1 serial protocol, and it also describes some IP addressing - 4.3 Send ASCII String to IP Address, p. 16.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 01-21-2010, 07:15 PM
David Richardson's Avatar
Sounds very possible via RS-232 but IP.. Don't think so.
David Richardson is offline
Old 01-22-2010, 11:08 AM - Thread Starter
rajah9's Avatar
Yes, I have cross-posted on Elk Dealer forum and CocoonTech. I ventured onto AVS because those questions have gone unanswered.
The post to the document was just what the doctor ordered! I'll hunker down and then report my progress. Thanks.
rajah9 is offline
