Want to automate a home theater setup with Denon 4310, electrical screen, projector, 8 lights and audio in the main zone and 2 other zones. All equipment is already installed, only need to add the HA.
Would like to include an iPod for music.
Researching systems, I came across the Prodigy. Main selling points seems "affordable" and "easy to setup".
Traditionally, Crestron is not open for DIY. Was wondering if the Prodigy system would be different or is also dealer-only install. Is important as I'm an expat living in Taiwan and CI's here are very hard to find, only focused on very high budget projects.
I learned from a Crestron dealer that the company requires dealer or custom installer status for programming Prodigy systems. Big disappointment as I was about to purchase a system.
Can anybody suggest any other options for the DIYer? I want IP control, several IR outputs, 2 RS-232 outputs, perhaps a few relays and contact sensors, iPhone/iPad 2-way control, HVAC control, etc. It is not clear on sites like Control4, Global Cache, Savant, etc. whether the controllers can be programmed by the end user. I currently use an MX-3000 RF setup to control components in a back room. OK but no 2-way, HVAC, etc.
Was still researching the Prodigy and I'm getting some help and advice from a dealer. However when I was about to order, Crestron seemed to have changed the focus of the product line.
A lot of the Prodigy products are being replaced by (what it seems) better ones. That would be great, but now my dealer is telling me I have to wait until late June to get a PMC2+ Prodigy system (the one with the PTX3 color screen remote).
He also states the current system (PMC2 with PLX2) will not work with new to be introduced products so buying the current one is not a good option for me as I want to start simple and build the system step by step over time.
Seems a bit strange to release a product and then change the line-up completely within one year.
He is giving you good advice but your conclusions seem to be overreaching ("change the line-up completely within one year").
When the processor was brought to market I believe a chip was not ready and they therefore had to use the current generation at that time. Now that chip is available and they are incorporating it into the new processor. This has resulted in an ongoing line change, and allows them to now offer the processor with the new RF color remote at a breakthrough price.
I don't know how long it takes for a product to reach your country but they just recently started taking orders for the new processor here in the US so I would guess that is a realistic date, hopefully even conservative.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
