Lutron Home Works Software Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-10-2010, 08:38 AM - Thread Starter
gaspower's Avatar
Hello,
I am using the latest Lutron software to program a HW processor 8 system. I am trying to download the current program in the current running system. It looks like when the last installer uploaded the file, it was a minimum upload, so when trying to download I get a message that says, since last upload was minimum, the down load file running on the system will not be the file running on the processor. Is there away to compile what is in the processor so I get the full running file?
Thanks JR
gaspower is offline
post #2 of 8 Old 10-13-2010, 08:31 PM
joatmonjf's Avatar
No. The "download" from the processor is the retrieval of a copy of the control program that was compressed and saved in a separate location in the processor during the last full upload. That's all that can downloaded, so whatever changes that were made since the last full upload will not be in the retrieved program.
joatmonjf is offline
post #3 of 8 Old 10-14-2010, 07:42 AM - Thread Starter
gaspower's Avatar
Thank you for the reply.
gaspower is offline
post #4 of 8 Old 10-29-2012, 11:57 AM
Lean835's Avatar
Hi, I have a Lutron HomeWork8 series and like to obtain the programing software. Anybody knows where I can download it for free? Thanks
Lean835 is offline
post #5 of 8 Old 10-29-2012, 12:01 PM - Thread Starter
gaspower's Avatar
Hello,
You can download it from here,
http://resi.lutron.com/
JR
gaspower is offline
post #6 of 8 Old 10-30-2012, 12:20 PM
Lean835's Avatar
Thanks a lot, I will try here!
Best Regards!
Lean835 is offline
post #7 of 8 Old 01-17-2013, 11:13 PM
Gingerjake's Avatar
How did you make out? Did you find the software?
Gingerjake is offline
post #8 of 8 Old 03-09-2015, 04:14 PM
Lean835's Avatar
NO I didn't, thanks anyway!
Lean835 is offline
Reply Home Automation
