Help in extending my existing Crestron Adagio System - AVS Forum | Home Theater Discussions And Reviews
Old 01-17-2011, 10:09 PM - Thread Starter
hehateme's Avatar
Hi:
I have an existing Crestron Adagio system. It has the following components:
AES
AAS-2
AAE
2 Touch Panels
3 APAD's
I have 2 home theaters(Denon 3808 and 4306) where the receivers are connected to AES with RS232.
I have Crestron ML 600 in each of these home theaters.
Everything is working fine at this time.
I am about to finish my basement where I will add my third and final Home Theater. Most probably I will buy another Denon like 3311CI.
How do I integrate my third home theater with the existing Crestron System.
The current receivers are connected to AES using RS232. However there are no more ports left on AES. So the only option left is IR control. Will this work well and is it as reliable as RS232 control?
Since I was happy with my current ML600 remotes I was thinking of getting another ML600 for the third home theater. Does this make sense? Is there another remote I should consider that is in similar price range.
Final question is about lighting control in the home theater. Because I am getting a projector I will have several lighting zones in my basement home theater. I want a simple dimming control solution just for the basement home theater. I don't want to light automation for the whole house at this time. Can someone recommend a lighting solution for 1 room. A friend of mine has Lutron Graphic eye and he likes it. But I was wondering if there is something else that will do a better job.
hehateme is offline
Old 01-17-2011, 10:31 PM
h34vystereo's Avatar
IR will work fine, but try a RMC box over Cresnet in the Basement. Once added to the AES, you can connect your new Denon using the RS232 port on the RMC. Program it, and you're all set. You can also connect local IR gear to this RMC box.
As for the remote, if you're using the rf gateways already in the system, then you should stick with the ml-600 for consistency and compatibility. I'd probably go with an RTI T2 using a CNRFGWA gateway.
h34vystereo is offline
Old 01-17-2011, 11:42 PM
CNRFGWA 433MHz
Old 01-18-2011, 01:45 AM
Blowne30M3's Avatar
ST-COM or QM-RMC. They both cost the same. ST-COM will give you 2 rs-232 ports since you are looking to add other things. QM-RMC will give you the one you need right now.
ML's are probably the most solid remote Crestron makes. If you're happy with it, stick with it.
Grafik eyes are great for single room control. That would be my recommendation.
Senior Crestron Programmer
XS Design Studios
Blowne30M3 is offline
Old 01-18-2011, 07:00 AM
Greg C's Avatar
You can control the 3311 over IP, so you don't need a 232 connection for that. Your integrator can give you more advise as well.
Greg C.
www.pghcustomht.com
CEDIA University Designer CAT Member
CEDIA University Instructor
Crestron DMC-E
Greg C is offline
Old 01-21-2011, 10:39 PM
Tony Golden's Avatar
The QM-RMC also has two serial ports.
Tony Golden is offline
Old 01-22-2011, 12:26 AM
Blowne30M3's Avatar
True story, thats what I get for posting at 1 am.
XS Design Studios
Old 05-22-2012, 03:50 AM
MarkPerf's Avatar
Hi all, I need some help please. I am trying to add a t-hub to a crestron adagio. All i need is for the sound to work thru the adagio. I have connected the audio to inputs on the AES and cannot get the system to recognise the source, What am I doing wrong? Any help for this AV noob greatly appreciated.
MarkPerf is offline
