Home automation frustration!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-20-2011, 02:07 PM - Thread Starter
MMMorish's Avatar
Okay everyone, I know that this topic has beaten to death, so I hope you experienced users can give me pros, cons, and tips to make my decision easier.
I've been researching a home automation system for a while now and due to my needs and budget, I've narrowed it down to Control4 and Prodigy. While I do think that both systems would no doubt serve me well, I'm looking for the perfect fit for my 3500sq/f home.
I've spoken to a few companies and they all have different things to say. The ones that install Prodigy say that the technology on it is better than that of Control4. The ones that install Control4 say the Prodigy has limitations that Control4 doesn't, and the ones that install both have mixed reviews about both. What do I do??
I will first start with a system that will, for now, control my home theatre system and reduce the number of remotes I have from 5 to 1. My HT is comprised of the following;
- Panasonic G25
- Onkyo TX-NR3007
- Paradigm in walls and sub
- Panasonic BD Player
- D-link Boxee Box
- Rogers HD Box
As budget allows, I would like to then expand my system to do dimmers (can't say how many), switches, HVAC, security, 2 channel audio for up to 8 rooms (that is until I complete my basement), and video for up to 8 rooms as well including my HT.
My questions for you pros on this forum are;
1. Which system is easier to program? I had one installer tell me that Control4 takes about half the time to program over Prodigy, thus saving me on costly install rates.
2. Which system has the most capabilities in terms of expandability? I obviously want to future proof.
3. Which system is more aggressively priced with its hardware? I'm thinking more along the lines of audio and video distribution throughout the home.
4. Since most of my music and movies are on digital downloads, which system will read off of my hard drives?
5. Which system will allow for simultaneous use by multiple family members at one time using devices such as iPhones or iPads?
I think I've covered pretty much everything. If there is anything I missed, feel free to chime in and let me know.
Also, if there are any threads which may answer a lot of my questions, please post a link for me.
I am comparing the newest equipment from each company, so that being said it would be the Control4 2.0 or whatever their up too now and Prodigy PMC3+ / PMC3-XP.
I really appreciate this great forum and all the help.
Nick
P.s I'd love to hear from people who have used/installed both as to eliminate any bias towards a single system.
MMMorish is offline
post #2 of 19 Old 01-20-2011, 07:27 PM
newgen718's Avatar
well with prodigy you get a well taught out homeautomation system.
control4 well be as good as the company thats doing your install.
hardware wise crestron has control4 with sleek design interfaces.
control4 still dont have a color handheld with docking station which is industry standards by now.
the company thats doing your prodigy sytem i would asked them to show me one of there large insalls using prodigy. Since they would have to do the additional 3 day training in order to more with prodigy.
prodigy is still in it's youth so if you wanna grow with them i would say prodigy.
newgen718 is offline
post #3 of 19 Old 01-20-2011, 09:03 PM
cowboy998's Avatar
I am in your same boat looking for a system for a similar sized home. We will have 8 zones of audio, 6 lighting zones initially, HVAC control and security system connectivity. In the future we would like to add distributed video and have wired for this.
We are leaning toward Prodigy for a variety of reasons. For one, the feedback I have gotten from some Control4 users is the issue of stability. In fairness these issues could be due to errors by the installer. I'm no expert on the programming end, so I can't speak in an educated manner to this topic.
I am also trying to build a system that will be scaled up over the next couple years and have come to the conclusion that Crestron is 800 lb gorilla in this field. This gives me confidence that they will continue to invest in the number expanding options (hardware and software) for the system. Also the new XP controller gives you access to Crestron's entire line. This to me is an advantage....albeit at a cost. Their full line gear is certainly not cheap.
I will be very interested to hear the replies of folks with much more experience the me.....
cowboy998 is offline
post #4 of 19 Old 01-20-2011, 09:27 PM
chomperoni's Avatar
Have you looked at the new élan G system? It is a very solid system and Élan has been around for a long time. I am building a home now and will be installing the system coupled with Lutron system for lighting.
I have looked at all the systems and found the Élan will do everything I need and more. Not that the other systems are not good but ultimately my decision came down to whom I felt more comfortable to do the install. I would not go control 4 as there are a lot of limitations with their system interfacing with outside components. Creston is definitely better but the cost of programming is the killer.
Élan is a happy medium if you don't want to spend 100k plus for a full house system. I also didn't like the fact that you need to call the installer to program any new components you add to the system. (like a tv or remote). This can make the future cost of the system a lot higher than you anticipated. I don't know if this applies to the prodigy system as I was looking at the full Creston system.
chomperoni is offline
post #5 of 19 Old 01-21-2011, 06:19 AM - Thread Starter
MMMorish's Avatar
I haven't looked into Elan because most of the AV shops I've visited only carry Crestron or Control4 or both. I know that a full blown Crestron system will no doubt be very expensive to program, but would the scaled down Prodigy system be just as complicated, thus bringing the programing rates to the level of Crestron??
You make a great point when you say that you want the option to expand and like yourself, I'm interested in the XP processor that will open up the possibilites of a larger and more "bells and whistles" system with Crestrons full SKU of goodies.
I too am very interested to hear from some of the more seasoned pros in the field and get their take on the best solution for my needs.
MMMorish is offline
post #6 of 19 Old 01-21-2011, 08:15 AM
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Originally Posted by MMMorish View Post
...I will first start with a system that will, for now, control my home theatre system and reduce the number of remotes I have from 5 to 1. My HT is comprised of the following;
- Panasonic G25
- Onkyo TX-NR3007
- D-link Boxee Box
- Rogers HD Box
As budget allows, I would like to then expand my system ...
Hmmm. So this is an existing house where you are going to have to cut into drywall to pull new wiring?
For your home theatre, you don't have to use an automation system--something like a Logitech Harmony remote will replace your 5 existing remotes and provide simple 'activities' that turn on/off the required devices and set the proper inputs with one button.
Then, you can talk to home automation companies at your leisure about what you want to automate and whether to go piecemeal or 'big bath'.
Craig
Pvr4Craig is offline
post #7 of 19 Old 01-21-2011, 08:37 AM - Thread Starter
MMMorish's Avatar
Craig
The home is existing, thought the basement is not finished so I can run anything I need to from there. If I need to then cut holes into drywall to pull wiring to the second floor, I'm prepared to do that as well.
As for the Logitech Harmony remote, I've looked into one and at $300, I'd rather save my money and spend it on an automation system that can do way more as a stand alone remote than the Harmony can, plus can be expanded to automate my home fully later on.
MMMorish is offline
post #8 of 19 Old 01-21-2011, 09:02 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
There is a new control platform coming from URC that looks interesting, called Total Control. URC is moving from single to multiroom - integrating audio, security, HVAC, IP cameras, and lighting.
I think it will compete with Prodigy and C4.
Looks like a combination of hand-held remotes and in-wall controls.
You might have to wait until Summer for it, and I really don't know much about it, but I've really liked their single room devices.
But, make sure you find a good installer, for whichever system you choose.
Total Control press release.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #9 of 19 Old 01-21-2011, 09:06 AM
Chicagorep's Avatar
If you can wait a couple of months for your install, URC is coming out with Total Home COntrol. It's going to be very slick and affordable with all the bells and whistles.
Chicagorep is offline
post #10 of 19 Old 01-21-2011, 09:27 AM
weddellkw's Avatar
The touchscreens they were showing at CEDIA had a noticeable lag in drawing pages while navigating...not unusable, but certainly not up to the standards people have after using the iPhone/iPad for the last 4-5 years. Have they been able to resolve that?
weddellkw is offline
post #11 of 19 Old 01-21-2011, 09:29 AM
ddave12000's Avatar
So, C4 is a poorly thought out system? Won't this be dependent on the integrator chosen? The answer, of course, is yes.
Insert Prodigy instead of C4 and the statement is true (for both products, of course).
A subjective opinion no doubt.
C4's entire platform is based around an onscreen control interface rather than a handheld as you describe. However, their remote is logical and easy to use. You get full 2-way menu structures through the LED screen on it if you desire. I do wish they had a charging dock for it though. You can also use iPod, iPad, and iPhone as a controller. I think android and PC apps will also be coming soon.
I would consider this to be true for both products. This will give you an idea of how the systems work and perhaps more importantly, what kind of work the integrator does.
prodigy is still in it's youth so if you wanna grow with them i would say prodigy.[/quote]
If this is true, then it's ever more important to make sure you get a well qualified integrator.
I work for a C4 integrator so I am biased towards it. I have no practical experience with Prodigy though I am sure it's a quality product. What's most important if you are ok with either interface is that you get an integrator you like, trust and knows their stuff. For the most part, any of the bigger companies mentioned in this forum - Crestron, AMX, C4, Elan, etc. - are all going to have good products and at the end of the day it comes down who's designing, installing, programming, and maintaining your system.
ddave12000 is offline
post #12 of 19 Old 01-21-2011, 02:44 PM - Thread Starter
MMMorish's Avatar
Are there any forum members in the Toronto, Canada, area that can recommend me a good integrater? Feel free to PM me with any suggestions for both Prodigy and Contrl4.
MMMorish is offline
post #13 of 19 Old 01-21-2011, 04:08 PM
39CentStamp's Avatar
I personally don't see this as a negative. The dead rechargable battery issue is a pain to deal with. Clients lose control of the system temporarily and then get hit with sticker shock for the proprietary battery.
There is help out there for you. First you must choose.. red or blue?
39CentStamp is offline
post #14 of 19 Old 01-21-2011, 05:08 PM
stefuel's Avatar
Quoted: 28 Post(s)
Liked: 24
Nothing beats a good blue job
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #15 of 19 Old 01-21-2011, 06:17 PM
ddave12000's Avatar
This is true and a good point, however, I would say I've had more complaints about how quick the batteries go dead than I have complaints about cost of proprietary batteries.
It's too late for me, I already took the AMX pill...it didn't seem relevant to the thread so I didn't mention it but I've been installing AMX for nearly 10 years. So, I guess you could say I'm even more biased towards that...
post #16 of 19 Old 01-21-2011, 07:26 PM
Blowne30M3's Avatar
Depends on the level of the programmer and how much expandability you want. I've done very cheap Prodigy systems and very expensive ones. You will just have to put together a list of what you want to do and bring it to your CI. I can help you put a product list together if you want so you have a general idea of cost with programming.
Senior Crestron Programmer
XS Design Studios
Blowne30M3 is offline
post #17 of 19 Old 01-21-2011, 09:26 PM - Thread Starter
MMMorish's Avatar
Lol are you saying that going with Crestron is embracing the blissful ignorance of illusion and going with Control4 is the painful truth of reality?? In the case of automation, is taking the blue pill an illusion?
MMMorish is offline
post #18 of 19 Old 01-21-2011, 09:40 PM
Chicagorep's Avatar
Well considering there were over a dozen UI being used at the same time, I'd say the fact that the network didn't collapse is pretty good. A little lag is to be expected when a system is pushed to that extreme.
post #19 of 19 Old 01-21-2011, 09:53 PM
LOL i knew someone would catch me! I was actually going to quote Morpheus incorrectly to keep you guys from noticing
Reply Home Automation
