Looking for some input/direction into some home automation. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-29-2011, 07:24 PM - Thread Starter
sandman512's Avatar
Good evening everyone. I am interested in accomplishing some home automation. Here is what I'm looking to do.
1) Key less entry with text alerts. Kwik Set vs Schlage?
2) HVAC
3) Light modules
All controlled via an Android app.
Thoughts?
Also, have a harmony 880 if that plays into it?
sandman512 is offline
post #2 of 4 Old 01-30-2011, 09:51 PM
iimig's Avatar
The Harmony can't communicate with any of those devices except for the light dimmers/switches possibly. I wouldn't recommend it as a whole house solution though.
If you break down each of those systems, there are versions of each that are IP which means the Android can control them (web-based though, not app based.)
If you really want it to be unified and app based (under one app,) you need a control system. The control systems I know that operate on the Android platform are Control4 and Crestron. They will have products that accomplish each layer of automation like lighting, HVAC, access control etc.
iimig is offline
post #3 of 4 Old 02-01-2011, 08:17 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
For a control system, there are several solutions readily available to DIYers. These include Elve from CodeCore, HomeSeer, Mainlobby/Netremote from Cinemar, CQC, others. These range from the very simple (easier, limited functions) to the complex (and powerful).
Each has their own forum.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 02-04-2011, 12:01 PM
Shady_'s Avatar
I use the Mi Casa Verde Vera/Mios system with Square Connect's SQ Remote. I use it with Schlage locks and Z-Wave lighting and thermostats. It really is the best bang for the buck IMHO.
Shady_ is offline
Reply Home Automation
