Apple TV (2) Integration Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-15-2011, 08:23 AM - Thread Starter
Nick Kallis's Avatar
Hey All,
I am having a Savant system set up right now. I understand that Apple TV 2 has not been able to integrate into automation systems/home control due to the protocol being changed.
I was curious if anyone had found a work around for this? I know I could use the original Apple TV but I've ripped a ton of movies that won't work on the original Apple TV due to using the Handbrake Apple TV2 setting so I am looking for a work around that doesn't involve me re-ripping the movies.
If it's not possible, does anyone have a solution to play all of my .mp4 files across my distributed video in the house?
Thx in advance for any help?
Nick Kallis is offline
post #2 of 5 Old 04-15-2011, 11:37 AM
fletch999's Avatar
Your ATV2 will stil play all of your movies and can be controlled with infrared by the Savant system, it just won't show you the metadata on the Savant system. You should still be able to see the ATV2 OSD on your TVs and navigate through that. Or, you could use the Apple Remote APP for ATV2 navigation on your iPhone/iPads.
fletch999 is offline
post #3 of 5 Old 04-15-2011, 07:14 PM - Thread Starter
Thanks and to clarify will the meta data show up in the OSD or just the titles?
post #4 of 5 Old 04-16-2011, 12:12 PM
fletch999's Avatar
On the TVs you'll see whatever the ATV2 shows, full menus, album/cover art, movie graphics etc. To get the ATV2 to multiple TVs you will need to have an HDMI matrix switch solution since it has no component video output like the original and the new one has digital audio only, but these are solvable problems that your integrator should have no trouble with.
Worst case scenario, put an ATV2 local to every TV, they are only a hundred bucks each.
post #5 of 5 Old 04-16-2011, 01:14 PM
tivogre's Avatar
One per TV was my solution. Easier and CHEAPER than the switches / cables to distribute.
tivogre is offline
Reply Home Automation
