Ex-link on Samsung plasma(PN63c7000) as IR port? - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2011, 05:34 AM - Thread Starter
juststartingout's Avatar
I'm trying not to stick an emitter on the front of my plasma if possible. I'm trying to set up an iPad as a remote. I'm using a global cache cg-100-12 and irule. It has been quite easy thus far (thanks to past pronto exp.). So I have everything working but why stop now. So I now want to get rid of as many emitters as possible. If the port will work I will most likely get a Xantech 79144 to control my cable box and tv. Otherwise I'll stick with the emitter path
juststartingout is offline
Old 05-08-2011, 12:27 PM
Dahwoo's Avatar
can the software/app do 232 commands? if so then it should work however you will lose ability to control network features of the TV if it has them such as netflix etc..
"I'm just a dog chasing cars. I wouldn't know what to do with one if I caught it"
Dahwoo is offline
Old 03-21-2014, 05:34 PM
Dave3245's Avatar
Why would he lose the ability to control Netflix?
Dave3245 is offline
Samsung Pn63c7000 63 Inch 1080p 3d Plasma Hdtv
