Escient Fireball flashing red light solved. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 80 Old 12-29-2012, 02:54 PM - Thread Starter
stefuel's Avatar
Quoted: 40 Post(s)
Liked: 26
It takes more than the correct voltage to work. It has to be clean power. Take the power supply off and look under the heat sink on the low voltage end of the supply. Look at the tops of the large capacitors for bulging or electrolite leaking from the top or bottom of those caps.
Read the whole thread here and look for the post on how to use a old ATX power supply to test the fireball.
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #62 of 80 Old 12-29-2012, 03:04 PM - Thread Starter
stefuel's Avatar
Quoted: 40 Post(s)
Liked: 26
Please read the whole thread before posting. Most of the replies here are people asking the same question over and over again. Everything that I know has been posted here.
I have worked on a number of Fireballs. Eighty percent of them were resolved with service to the power supplies. The rest I could not fix because the schematics and recovery discs are locked down.
stefuel is offline
post #63 of 80 Old 12-30-2012, 10:17 AM
gedeon25's Avatar
I fixed mine
Will explain you lately how, but now it's time for new year party.
@Stefuel : did you récrive my mail?
GeD
gedeon25 is offline
post #64 of 80 Old 12-31-2012, 08:30 AM
fargozombie's Avatar
gedeon25...I did measured the power supply with an O'scope verifying voltage and waveform.
I did receive a response from Escient Support and I was provided a link to the firmware to to perform a manual firmware update.
Has anyone attempted a manual firmware update on a DVDM-300 using the CD drive?
if so, what was your experience/outcome with this?
Probably won't try this until after NYs
Cheers,
fargozombie is offline
post #65 of 80 Old 01-04-2013, 01:56 AM
gedeon25's Avatar
So,
How I fixed my E2.
First of all, I open the case, disconnect the 10 wires link (10 cm) between power supply and motherboard. I put a big external ATX power supply from my home PC.
I swap the IDE cable with a brand new I have at home, but the one I putted is only for test (one plug is not on the good position, have a look on regular IDE ribbon and you will see what I mean)
I'm lucky and I have in stock a golden disc from Escient to set up new hard disc drive so I putted on my E2 a new HDD (750 Gb IDE)
Escient explained that when you want to do a manual firmware update, you have to disconnect your LAN.
ok, all ready, let's go.
After 5 minutes, update disc didn't boot... (bad news)
So I decided to reboot the machine with LAN connected !!!
>>> after 2 or 3 minutes of LAN activity, screen told me : update in progress, please wait (downloading) GOOOOOOOOOD ! downloading of the firmware took 10 minutes or more.
flash succesfull, reboot the machine with golden disc inside and 5 minutes later, a working E2, like new.
After that, I reconnect original IDE ribbon and reboot >>>>> ok
I reconnect original power supply and start again >>>>>> ok
So, my experience is that sometimes, electric problems on your AC power may hang your motherboard, and as Escient did not put a BIOS RESET switch, you have to force the system with a new firmware update (that will reset your bios conf)
Of course, if we need a perfect power supply, you have to check your capacitance on P/S as Stefuel said !
gedeon25 is offline
post #66 of 80 Old 06-06-2013, 07:33 PM
uchujin2's Avatar
Hi All! Please help a non-techie! My E2-300 is acting up and I'm not sure where to start. I have read the entire thread and what's happening with mine doesn't sound like all the others. When I power it up, I get the Fireball startup screen.....then it says it is performing backup functions but the progress bar never moves and then it clicks over to the Software Update function. It says "Connecting to server. Please wait...." It never connects or downloads, but after several minutes clicks off and automatically restarts. The results are the same whether or not my LAN is connected through the ethernet port.
uchujin2 is offline
post #67 of 80 Old 10-25-2013, 03:19 PM
chappatti's Avatar
@gedeon
I am jealous of you !!!! And I am itching to get my Escient turned on!! And I hope you can help me.....
1. I can see video output on my screen but it says "Startup Problem" "Unable to find software..........."
2. So I presume, rebooting the machine with an external ATX may work.
BUT:
A. I do not full get how to connect the external ATX . I read the post from earlier, but the wiring as explained I am kinda unsure of. Can this be explained more detailed? A picture, perhaps?
B. I DESPERATELY need a copy of the Golden CD. Can you please PM me? I can pay for you to ship me a copy............
Please, please reply !!!!!!!!!!!! Aaarrgghh.......
chappatti is offline
post #68 of 80 Old 10-28-2013, 02:15 AM
gedeon25's Avatar
CHAPPATTI :
you need to connect the external ATX power supply plug to the Escient motherboard (the plug is on the right side of the motherboard when you look front of the unit.
Do you hear the HDD spin or not?
your problem can be on 2 levels
1) your hard disk had a soft problem (power supply cuts during HDD writing)
> in this case you juste need to rewrite boot sector > in this case you do not lose your music
2) your HDD is dead, and you need a new one
> in tris case you must do a full install and format, and you will lose all your datas.
What's your machine? E2 ?
regards,
GeD
gedeon25 is offline
post #69 of 80 Old 10-28-2013, 02:17 AM
gedeon25's Avatar
same reply as chappatti. you lose part of the boot program and your unit tries do connect to Escient Server to upgrade. Unfortunnatly, Escient Servers are now down.
you need a golden disc.
gedeon25 is offline
post #70 of 80 Old 11-05-2013, 07:27 PM
chappatti's Avatar
Originally Posted by gedeon25 View Post
CHAPPATTI :
regards,
GeD
Thanks so much for replying..
Yes, it is a E2.
1. The hard drive spins and is very quiet, no clicks or stuff. So I assume it is OK. But it could still have failed.
2. Since I get a video display (with error about unable to boot --no software etc), it looks it all problems are in HDD
3. I can reformat - I am willing to give up the data to get this fixed !!
I have another question !! While I was trying to get the E2 up, I also bought a used DVDM-100 (DVD manager). Yeah, I am nuts like that !!!!!!
From the previous owner, this has a password protection, but I cannot get the password. He does not remember the password. The password is preventing me from accessing the regular setup menu - it is in guest access mode. Is there anyway to factory rest any Escient without password or anything?? These things are annoying !!!!! :-)
post #71 of 80 Old 11-10-2013, 07:45 PM
alexsquared's Avatar
Not sure if this bypasses the password or not, but hit setup then 8020. This normally takes you into a deeper setup menu.
alexsquared is offline
post #72 of 80 Old 11-22-2013, 02:47 AM
thedo's Avatar
Try these for password to get into setup menu : 3473, 96843468, or 8675309
thedo is offline
post #73 of 80 Old 11-25-2013, 12:51 PM
chappatti's Avatar
I already got these passwords from Escient support....... some VERY good soul replied to my email !!!smile.gif
And I can say they work !!
Thanks anyways for putting these out here for other folk ..........
PS: pm sent
post #74 of 80 Old 09-14-2014, 04:19 PM
hyebrother's Avatar
I have a DVDM-300 and its doing the same thing. red light flashing and no one is home..nothing pops up on screen.
Anyone have a detailed way to test the unit with an external atx power supply? as I understand this is a power supply issue. or where to get a new power supply for it?
thanks
hyebrother is offline
post #75 of 80 Old 07-21-2015, 06:19 PM
rdeckard2019's Avatar
Exclamation
Not sure anyone's looking here anymore, but I have an Escient Fireball E-120 that was in use for a while then replaced by a Squeezebox setup.
It was working fine up until it was taken out of my system.
I am trying to get rid of some excess gear and figured I'd try to unload this thing on the 'bay, so I took it out of storage and fired it up.
So far, all I get is a flashing blue (not red) LED by the power button and the CD tray ejects after a minute. I get no front panel display or video. Tried composite and VGA. Have left it for 10-15 minutes at a time with no luck in any scenario.
I read this entire thread and tried the following:
- Reseated all connections/cables.
- Removed HDD tray and inspected power supply (no swollen or leaky caps I can see - everything looks very clean).
- Tried booting with and without Ethernet connected. When connected, it does grab an IP and can be pinged, but I am not able to pull anything up in a browser.
I saw someone mentioned that their fan wasn't running. Mine isn't either. Haven't tested the actual fan yet. I know some mobo's won't boot if a system fan is faulty, but that's literally the last thing I can think of trying, aside from digging out another ATX supply or recapping, which is probably a waste at this point.
Escient is now out of business and all links to their site bring up a bankruptcy notice...
Any other suggestions? Can I perform a factory reset without being able to boot? Is the tray ejecting on startup because it's looking for a system disc?
If so, does anyone have an ISO of the OS they could share?
Thanks for reading!
rdeckard2019 is offline
post #76 of 80 Old 09-18-2015, 03:32 PM
Liked: 0
hi everyone,im new and not very electronically savvy
i got hooked on escient products a couple years ago when i found one at goodwill for under 10 bucks.it was an se-80 but i didnt get it going till about 6 mos ago ,ive never heard or seen these before that so when i fired it up i was so phyced that it had a ton of my favorites on the unit.i used to be able to burn cd's for my car on all 4 of my units just a few months ago but when i try now it rejects them saying that it was not a royalty paid media.ive tried buying 3or4 spindles of all types of cd-r,dvd-r s etc from different makers sony,memorex,maxwell and phillips im really confused!and to make things worse,the e-120 that most of my favorites were on all of a sudden started saying checking the library but even after being left on overnight never got past 80%.i got a new power source on ebay ,changed it out no problems except for now the front blue light will not even go on.so first i changed the fuse,still no light.so i put the old power supply /fuse back in the unit still not even a light,but i could see the green light on behind the cd/door.anyway im still kinda in summer mode as i am 65 years old retired with some work disabilities and on a very tight budjet.i eventually just want to get all my music together as i ruined all my cd's and i have a ton of cassettes from the old days.its funny though that i can make a data mix cd that fits triple the amount of music,plays in my home deck but wont play in my 02, 6 cd changer in my car.anyway i'll probably be driving you guys nuts,but ill try my best not to. i slowly accumilated 2-e120,1 works--2-e40,one works,1 se-80 works,and 1 dvdm-300 that works after putting in a new cd assembly from my parts e-40.
lovemyescients7 is offline
post #77 of 80 Old 10-06-2015, 09:09 AM
Liked: 0
resolved recording
finally found some very good recording discs/cd's memorex music--cool colors
next very important issue to me is to try and transfer an awful lot of my favorite music burned to hardrive in an e-120 that all of a sudden would just go into "checking library"mode where it would only reach 80% completed period,so i could never access my music since .i bought a new powerboard ,didnt work at all (maybe different even though looked identical).so when i put the old board back in i got nothing at all ,wouldnt even power up.so i got an identical hardrive hoping to be able to recover and clone my music on it,if the hardrive is the problem.anyone with any helpful info please advise--thank you
post #78 of 80 Old 11-14-2015, 07:07 PM
BJBBJB's Avatar
Quoted: 39 Post(s)
PC import to fireball no longer works
Just figured I'd give a shot at posting in case anyone is still following this thread that is still nursing along some fireballs.
Longtime fireball and DVDM user. My E-120 still play fine but now when I try to copy an MP3 to the "import" folder on the fireball from a PC, the copy freezes and won't complete. I got one or two tracks to copy but no matter how I tried, the next one or two froze mid-copy.
I already tried using teracopy in compatibility mode....that resolved a skipping issue introduced with Windows 7. However I have not installed any updates or made any major PC changes. And yet, I can see the folders over the network.I just can't copy anything to the import folder either windows windows file explorer or teracopy.
Importing from a CD was still working last time I tried that. However these days, a lot of my music starts life as an MP3 not a CD so I would really like to use the import function.
Any ideas?
BJBBJB
BJBBJB is offline
post #79 of 80 Old 11-27-2015, 03:38 PM
Liked: 0
Thanks for reading!
I read your message from this past July about your Escient Fireball E-120 blinking blue light issue and I am wondering if you were able to resolve it. I, too, have the same issue with my E-120 and haven't been able to fix it. If you were successful in fixing it, I would appreciate your input as to how you did it. If not, what music manager system would you recommend to replace the Escient? Is it possible to remove the Escient hard drive and download all of the music onto another device?
Thanks for taking the time to respond to my questions.
MDThompson356 is offline
post #80 of 80 Old 11-27-2015, 03:39 PM
Liked: 0
Reply Home Automation
