Remote Controlled Vertical Blinds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-03-2011, 11:03 PM - Thread Starter
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
Hi all,
I plan to purchase and install Remote Controlled function for a Vertical Blind. But have no clue where to start from. The window is 8-9 ft wide by 8-9 ft in height. Should i just install a wireless kit that comes along with a remote and a motor to the existing blinds? Or the there is a entire Vertical blind with integrated motor/wireless option. What is good. Ofcourse i dont want to make it ultra expensive.. The usage will be minimal, maybe 4-5 times a month when i will be opening the blinds on the window.
I prefer both tilt, and opening of the blind with the remote.
Please guide.
holyindian is offline
post #2 of 11 Old 07-05-2011, 06:53 AM - Thread Starter
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
Any help appreciated..
Desperately looking for a motorized vertical blind.
post #3 of 11 Old 07-05-2011, 09:42 AM
Deane Johnson's Avatar
I'll look into it for you and report back. Things keep changing regarding availability, so I need to refresh myself.
I know you can accomplish it with BTX, but these are probably overkill for your use.
http://www.btxinc.com/products/verticals/slenderline
Deane
Deane Johnson is offline
post #4 of 11 Old 07-05-2011, 10:03 AM
Hunter Douglas verticals can be motorized with tilt only. No traversing. They use the Platinum 2.0 system.
There are probably others, but I am not familiar with who they may be.
You should be aware that the words full motorization and "not expensive" don't belong in the same sentence.
post #5 of 11 Old 07-17-2011, 04:47 PM - Thread Starter
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
Thanks for the suggestions. I guess vertical blinds are so common in big houses, but lack of motorized blinds makes no sense to me. I have been googling for days but no result.
post #6 of 11 Old 07-23-2012, 03:06 PM
jpsoutlook's Avatar
I am looking for some as well, what did you find?
jpsoutlook is offline
post #7 of 11 Old 09-18-2013, 03:46 PM
conanb's Avatar
Quoted: 13 Post(s)
I am trying to figure out if I can build an IR controlled mechanism using Lego Power Function components to pull the existing chain that controls the tilt of my vertical blinds.
conanb is offline
post #8 of 11 Old 09-18-2013, 06:13 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Lego motors are probably more expensive than the Somfy alternative.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #9 of 11 Old 09-18-2013, 06:54 PM
conanb's Avatar
Quoted: 13 Post(s)
Check out Lego power function modules on www.ebay.com and www.lego.com... cheaper than somfy.
conanb is offline
post #10 of 11 Old 09-19-2013, 04:41 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Wow, that is pretty cheap.
I'd have concerns about torque, and life expectancy. Which motor are you trying to match?
http://www.floridaautomatedshade.com/Somfy_Motors_DC_s/162.htm
Hardwired power?
post #11 of 11 Old 09-19-2013, 06:14 AM
conanb's Avatar
Quoted: 13 Post(s)
I have not come up with a configuration yet.
I just want to be able to tilt the vertical blinds, which would involve pulling/pushing/rotating the chain that does not require much effort.
The window I have in mind is only 70"w x 22"H. I will do plug in if feasible, but not necessary.
conanb is offline
Reply Home Automation
