IP or Telephone Garage Door Opener - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-15-2011, 03:09 AM - Thread Starter
brentdh187's Avatar
Hello all,
I've been reading quite a bit on this but all the info seems to be a couple years old. I am looking to open and close my garage door with my Android phone. Either by an app, the internet or actually calling it. I ran 2 cat5e runs from the garage door opener to the basement panel before sheet rock. I dont have any home automation software at the moment. at the moment, and I'm sure I will change my mind, I only want to control my garage door from my phone. I want to be able to use it from afar so bluetooth and wifi are out. Thanks and have a great day.
brentdh187 is offline
post #2 of 11 Old 12-15-2011, 08:40 AM
snidera's Avatar
It's going to depend a lot on what other hardware you have available, but here is a fairly simple & cheap idea that would work.
You will need:
PC on all the time.
Teamviewer, remote desktop, logmein, etc on PC & a phone that supports that software (I used teamviewer).
I/O card connected to PC. Fusion Brain is the one I use for stuff like this (check the support forum at Mp3car.com)
You'll either need the Cat5 ran to the PC or a USB + 12V to where the Cat5 is to power/control the Fusion Brain.
This is going to depend somewhat on the door openers, but I think they are mostly the same. I'm writing this based on my genie openers & the fusion brain. For my method, you'd need: 1 fusion brain ($60ish, for v4, you get 15 ouputs, 12 inputs, you could control 6 garage doors with my method & have outputs leftover), 2 relays, 1 cat5 per door. you could use 1 cat5 for 2 doors with some common grounding, but seems more complicated than running the 2 cat5 you already have....
Use 1 pair from the cat5 to simulate a press of the wall button via a relay. That will cycle the door just as if you pushed the wall button. You'll probably want to use diodes to keep the switches from interfering. This is 'dumb' in that you won't know if the door is going up or down, opened or closed.
To make it smart, add limit switches for open & closed. Use 1 cat5 pair for open, 1 pair for closed (some openers may have this already to be piggybacked). You can then use logic to decide if what you want to do should be done (ie-if you hit 'close door' and the door is already closed, the software ignores the command & tells you you're a dummy.). You can get as creative as you want with the logic software - run a GUI on the PC & just use remote desktop to click a button, make your own iOS/droid app, make a web GUI & expose that to the 'net, and so on.
The fusion brain just got a hardware update to v6, but the software isn't done yet (usable if you're familiar, but a PITA, IMO - C# +XML puts me off). the v4 will do all you need (and have inputs & outputs to spare) and has software available that will be easier to start out with. (if you know VB6 or .net, PM me and I'll send you some source that will get you up & running even easier than fusion MDX)
snidera is offline
post #3 of 11 Old 12-15-2011, 05:35 PM - Thread Starter
brentdh187's Avatar
Wow thanks that info will keep me busy reading for awhile
post #4 of 11 Old 12-17-2011, 05:40 AM
shaun5's Avatar
I think this would be useful, but... you need an audible warning when the door is activated to be up to code. Lift Master and Craftsman (rebranded Lift Master) have openers that are controllable by an app (and have the audible warning).
Global cache makes a contact closure itach ethernet and wifi devices.
shaun5 is offline
post #5 of 11 Old 12-19-2011, 11:46 AM - Thread Starter
brentdh187's Avatar
Has anyone used Irule app with the Itach for a garage door opener? Will the Irule work if I am away from my local wifi network? Say my mother stopped at my house and needed to get in could I log into Irule with my phone and open the garge door?
post #6 of 11 Old 12-19-2011, 12:03 PM
shaun5's Avatar
I don't use Irule, but can control my system (includes an iTach) remotely. I use Girder.
To work away from the house, you will have to:
1)have an ip that is visible from the internet.
2)if it is dynamic, either keep track of it or use something like no-ip.com.
3)forward some ports from the router to the GC or use a VPN connection.
shaun5 is offline
post #7 of 11 Old 12-19-2011, 05:25 PM
snidera's Avatar
What is the audible warning?
Does it go off every time you open\\close (no matter the trigger method)? Or is it only for 'remote' opening (not via the short range car remotes).
Sounds kind of dumb to me, you have the eyes to make sure the path is clear, if you're working on the opener, you need to cut the power anyway (or block the eyes if you need the power on for some reason).
The only way this remotely passes 'stupid code ********' is if the audible warning is a submarine siren accompanied by 'dive, dive, dive'
snidera is offline
post #8 of 11 Old 12-19-2011, 08:10 PM
shaun5's Avatar
A beep or siren i suppose. I don't know when it sounds. I don't write the codes, but I think you have to have line of sight with a traditional opener button.
shaun5 is offline
post #9 of 11 Old 01-24-2012, 02:24 AM
dinnovative's Avatar
A wifi garage door opener that I just crafted based on a simple wifi microcontroller (Roving Network's WiFly, 802.11b/g).
Includes a magnetic switch to detect door status and a web page interface that fits nicely on a smartphone. A pretty straightforward build -- only took me a couple of weekends to conceive, craft, and install.
www dot dinnovative dot com -- look in projects (sorry, don't have URL posting rights yet!!)
thnx!!
tod
dinnovative is offline
post #10 of 11 Old 02-17-2012, 09:36 AM
silvermaxd's Avatar
I just ordered one of these on amazon...Liftmaster 828LM Garage Door Opener Internet Gateway
Steve R.
silvermaxd is offline
post #11 of 11 Old 02-17-2012, 11:21 AM
shaun5's Avatar
You ordered a compatible opener too, right?
shaun5 is offline
Reply Home Automation
