What do I need for a dimmable IR setup that'll work with dimmable LED bulbs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-31-2012, 04:45 PM - Thread Starter
gundam83's Avatar
I have a harmony 900 that I would like to use to dim the two recessed ceiling lights in my theater room. I want to be able to use dimmable LED bulbs with this setup. Custom scene settings would be nice but not critical. At the very minimum I want to be able to turn the lights on and off with the harmony remote. The Lutron Maestro seems to be a popular choice with harmony users, but I can't find any information on how well it works with LED bulbs.
gundam83 is offline
post #2 of 2 Old 01-31-2012, 08:06 PM
jautor's Avatar
Quoted: 1327 Post(s)
Liked: 850
As long as the LED lamp is dimmable, you should be fine. Just be aware that most dimmers have a minimum load requirement - with LEDs you might be underneath that if you've only got a few on the circuit.
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
Reply Home Automation
