Controlling a computer in basement with keyboard upstairs. - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2012, 09:32 PM - Thread Starter
sbaker512's Avatar
Hello,
I have all my audio video equipment in my basement, and its ran over cat5 to the TV's, then converted back to HDMI. So I can use watch my Tivo's on any TV in the house.
The problem is, I watch a lot of stuff on the internext (Netflix, amazon prime, etc). So I usually hook a laptop right into my receivers and control it via a wireless remote.
I would like to put a computer downstairs, and select it just like I select Tivo1 or Tivo2, using my Universal MX-880. All this I can handle.....the problem is, I need a wireless laptop of some sort to work the computer, whiles its downstairs, and I can't seem to find a product (or keyboard) that would work over that kinda distance. I can't believe nobody has ever done this before! Any idea guys!
Thanks for your tiime
sbaker512 is offline
Old 02-10-2012, 07:13 AM
alexsquared's Avatar
If you have an iPad, iPhone, or android, download the TeamViewer app.
alexsquared is offline
Old 02-10-2012, 07:24 AM
MasterofBlasting's Avatar
Originally Posted by sbaker512 View Post
Hello,
How far is the run from your PC to viewing area? If it's possible, you could run a usb cable from the PC to your viewing room, most likely usb over ethernet, and simply buy a wireless mouse and keyboard combo that use the same usb wireless adapter. Have the keyboard and mouse's usb adapter in your viewing room, and simply use this to control your PC.
I've seen this done before, and it works very well.
MasterofBlasting is offline
Old 02-13-2012, 02:37 AM
cntp's Avatar
cntp is offline
Old 02-13-2012, 01:23 PM
mmcxiiad's Avatar
why not just use remote desktop or VNC or some other similar software to control the computer is the basement? Then use a tablet (iPad, kindle fire, iPod touch etc)
mmcxiiad is offline
Old 02-14-2012, 12:45 PM
Shady_'s Avatar
If you want to go the app route, I am pretty happy with Mobile Mouse. It has keyboard/mouse and some media controls and other customizable buttons. I access either my Mac or my PC on any TV in the house. There are many apps to choose from in this area and it tends to be easier for HTPCs when you have some type of media controls in the app so you're not having to mouse over to the onscreen controls every time.
Shady_ is offline
Old 02-21-2012, 10:20 PM
hedg12's Avatar
If you have a laptop at your viewing location, you could use Synergy to share your keyboard & mouse with your media PC.
hedg12 is offline
Old 04-03-2012, 03:44 PM
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
What's your total cable distance from the computer in the basement to the viewing room? You're already distributing video, so you've got that covered. What you need is the keyboard and mouse. Those are slow devices, you can use USB1.1 to drive them. There are a lot of USB over CAT5 extenders out there (usually USB1.1). There are a few USB2.0 extenders, monoprice sells a couple of lengths. This might work depending on how far the cable would need to be. Once you get close to the viewing area in which you want to control it you could use a wireless USB setup common to most keyboard & mouse combos. You could, conceivably, use more than one such extender for multiple keyboard/mice locations. Granted, they'd all be controlling the same computer, not individual sessions, but you have that situation already with your remotes.
Logitech makes a nice keyboard/trackpad combo, the K400. It's cheap too. I also have a Dinovo and can't really justify it's expense over the K400 for limited use scenarios. I wouldn't want to be typing for any duration on either of them, but the K400 does a bang-up job on my treadmill.
wkearney99 is offline
