Anyone here Google+? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-28-2012, 05:19 PM - Thread Starter
IVB
IVB's Avatar
Just curious. I'm pretty active on it, then again I almost never actually post on HA/HT stuff. After going through hell & back setting up my system, I'm pretty content to sit back and enjoy it. Even if it doesn't do 50% of what others seem to be doing nowadays :-)
Yes, I'm "that" Home Automation Guy.
IVB is offline
post #2 of 6 Old 02-28-2012, 08:33 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Welcome back.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 6 Old 02-28-2012, 10:29 PM - Thread Starter
IVB
IVB's Avatar
thx, I suppose its by choice. I did some internal reconfiguration/remodeling, putting in new LED lights in a "new" room, now back to cocoontech & here to see if anyone has used automated dimmers with them. Seems deceptively simple, they're 2 wire, which is right about when I find out something and get hosed :-)
IVB is offline
post #4 of 6 Old 02-29-2012, 06:09 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You should buy lights that you know you can control.
Look to Lutron for LED control solutions. I'm sure they have an automated dimmer that works with LEDs, though perhaps not the ones you have installed.
Might be worth it to add RA2 to the mix, for future LED zones. Your plaster and lathe will put up a fight, but it will lose.
Neurorad is offline
post #5 of 6 Old 03-01-2012, 12:55 AM - Thread Starter
IVB
IVB's Avatar
The wife bought the lights. Spent 4 hours at HD without my knowledge.
Translation: These are the lights we'll be using. My opinion is irrelevant. Now to find automated switches that work within that constraint :-)
IVB is offline
post #6 of 6 Old 03-01-2012, 04:07 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I'm currently in a similar situation with kitchen pendant lights. I understand.
Neurorad is offline
Reply Home Automation
