Sending RS 232 Commands - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-02-2012, 03:56 PM - Thread Starter
mattracer92's Avatar
Hello,
I have a viewsonic pjd5111 with an rs232 port on it. I have it mounted up on a ceiling and the IR remote is cheap and does not always work. I ran an rs 232 cable up when I mounted it just in case. Now I would like to use it, the only problem is I don't have any experience with sending the commands to the projector over RS 232. I have the list of commands, I just don't understand how to actually send them to the projector from the computer. Any help would be much appreciated!
mattracer92 is offline
post #2 of 12 Old 03-02-2012, 05:18 PM
alexsquared's Avatar
Originally Posted by mattracer92 View Post
Hello,
Unfortunately sending commands straight from a pc won't be very elegant. Your options are using something like hyper terminal to send the commands, or do something like writing batch files. Or who knows, maybe there is an inexpensive automation software you can use. My experience is with automation controllers like AMX,/Crestron.
alexsquared is offline
post #3 of 12 Old 03-02-2012, 06:12 PM - Thread Starter
Yes I have tried using hyper terminal but I am not sure how to enter the commands. I believe that I have everything setup properly its just that the projector doesn't do anything when I enter the command. If the command Viewsonic gives is "0x06 0x14 0x00 0x03 0x00 0x34 0x11 0x00 0x5C" then is that EXACTLY what I type in to hyper terminal or should it be something else?
post #4 of 12 Old 03-02-2012, 06:38 PM
Dean Roddey's Avatar
Quoted: 387 Post(s)
Liked: 293
No, that's a text dump of the commands values in hexadecimal. It's a binary protocol and you couldn't do it via Hyperterminal really. You might learn some useful stuff from this document I wrote up about control protocol design. The first sections are high level views of the kind of things you need to understand such as the difference between text and binary protocol:
http://www.avsforum.com/avs-vb/showthread.php?t=1370544
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
www.charmedquark.com
Dean Roddey is offline
post #5 of 12 Old 03-02-2012, 06:40 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Read through remotecentral.com 232 threads for a couple dozen hours.
You'll need a controller that can send rs232 commands, or a PC.
You should try an RF remote first, much less effort to figure out. IR is OK, if done correctly. The RF remote sends RF commands to a controller, which then sends IR to the components.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 12 Old 03-02-2012, 06:52 PM - Thread Starter
So basically, there is not a fairly simple way to control a projector using a computer via rs232? Bummer. Thanks anyways guys!
post #7 of 12 Old 03-02-2012, 07:05 PM
Quoted: 387 Post(s)
Liked: 293
You may find some simple utility out there that will take a list of binary values on a command line and send them to a given serial port or something.
Dean Roddey
post #8 of 12 Old 03-02-2012, 11:28 PM
jmaxbrod's Avatar
Get an RTI remote and they have a small processor receiver with serial and IR. You can control equipment and control via 1 way rs-232 the projector. It's not DIY though, you will need an RTI dealer as they are not sold otherwise
jmaxbrod is offline
post #9 of 12 Old 03-03-2012, 12:31 AM
Zellarman's Avatar
iRule and an iTach is another option to the RTI and it's DIY
Zellarman is offline
post #10 of 12 Old 03-03-2012, 12:29 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Yes, there is a way.
Why would you want to use a PC?
Neurorad is offline
post #11 of 12 Old 03-03-2012, 04:32 PM
jmaxbrod's Avatar
X2.... This is a very simple and common situation. I'm not sure spending hours bombarding yourself with hyper terminal and protocols and depending on a computer just to be able to turn on a projector in a way more convenient than using factory remote and aiming it up makes sense. For me, I have to provide my clients reliable control, and RTI is one of my preferences. However like mentioned earlier you can get the rs232 itach and use irule or a similar app too. You don't need a 40ft donzi to float down a river, a canoe works just fine.
jmaxbrod is offline
post #12 of 12 Old 12-17-2012, 07:56 PM
alfred timeo's Avatar
you can buy a USB to 9pin cable and download a software named : docklight to control you projector using PC.
alfred timeo is offline
Reply Home Automation
