RadioRA 2 Software, Any Installers Not Nearby? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 87 Old 08-05-2013, 06:34 AM
Sparkycoog's Avatar
I know this was posted almost a year ago but I found the thread by googling around since I've had customers ask me for the software as well and I'm sure others might be googling this too.
Before I go on my rant, I should mention that Lutron does in fact give homeowners a lot of power by letting them change scenes using the tablet apps for Android or the iPad AFTER the system is installed and running. You can also do an old fashion install using pressing and holding but it won't ever be compatible with apps or anything else. I should also mention that Lutron is the ONLY wireless system I have used that always works and looks good doing it. Nothing else even comes close, especially those mesh networks. This is a fixture of the house so if you use a Radioshack style "open" network, good luck with it working and good luck finding parts later.
The reason why I'm against giving the software to customers is multifold.
Business reasons:
Between Lutron and Vantage, our company (which shall remain anonymous because I'm not here to drum up business) has invested 10's of thousands of dollars and many hours on training and CE courses and we're a small company. On any given day, I can be called to service a system and the Homeowner only says it's a "lutron" system. Is it radio ra classic? radio ra 2? Chronos? Homeworks interactive? Homeworks Illumination? Homeworks QS? "the original" Homeworks? Very few electricians can service all of these systems and AV companies can't replace electrical parts (legally in most areas) so add all the electrical licenses involved to the equation and realize that I'm not going to give this away for free without expecting something payment.
"But I'll buy the parts from you". Great. Unless you're buying enough parts for a big corporation, the profit margin on parts is very little because Lutron has many hands involved in distribution so I would be lucky to get 10-20% profit. Subtract income tax, franchise tax, and all the time it took to negotiate this with a difficult customer and it adds up to walking away. The way we make our return on investment is through the complete installation package and labor and future service calls.
I also appreciate Lutron not giving the software away because they have to protect their dealers. We invest a lot in Lutron and install their systems right. A customer who gets in trouble will blame everybody but themselves.
Technical reasons
This is my favorite part. My background is computer science and it's amazing to me how much customers, especially those from a technical background underestimate the things that can go wrong. On the surface you just design the system and tell a button what to do and you're off and running. The reality is different.
Do you even know what to order?
Do you know about the wattage requirements of the dimmers? How many dimmers can you put on the system? Would you need to link two systems? Do you know the difference between electronic loads, magnetic loads, fan speed controls, relay loads, how many repeaters you need, etc?
Do you know how to wire these dimmers, links, or panels in case of Homeworks? I know of many seasoned electricians who can wire a big scary 480 volt industrial machine who can't figure out how to install a 4 way Lutron Dimmer or replace a thermostat with a Lutron/Honeywell thermostat.
Let's assume you've managed to install all the parts or had someone else do it and you want program them and someone gave you the software and you managed to figure out how to do the programming on the software. What do you do if something goes wrong during the upload? Say a dimmer didn't have light bulbs installed yet or you got a screen full of red warnings that dimmers failed. Can you troubleshoot that? What if you want to add or remove parts from the system, can you do that? I did a job with two main repeaters where during my upload someone knocked out power to the repeaters in one system and somehow part of the system became orphaned and got a different house address. After spending hours on the phone with Tech Support, it was decided to factory default the entire system. There were also networking issues (not my network) so the upload would take nearly an hour so I had to find workarounds around that and I've installed many systems and it still took everything I had so the homeowner could use their lights that night.
Can you handle all that? If you can't, it would cost you much more if you call the pros in after you're stuck. Once to factory default and undo everything you did, another to replace the dimmers you blew out, and lastly to start from scratch.
Sparkycoog is offline
post #62 of 87 Old 08-05-2013, 08:20 AM
az1324's Avatar
Quoted: 24 Post(s)
Isn't that a good thing for dealers? Let the customer try and fail and then you're the hero and they are at your mercy and they realize how valuable your services are.
This penalizes the customer by preventing the market from providing an efficient supply chain.
Otherwise all the problems you list are due to poor design/documentation. As HA products move from luxury to commodity this will change. There will still be a place in the market for the HA equivalent of an interior designer but there will also be a place for a geek squad type franchise service. Currently there are not enough solution providers that cover the range of desired services.
az1324 is offline
post #63 of 87 Old 08-05-2013, 08:58 AM
wkearney99's Avatar
Quoted: 342 Post(s)
Liked: 131
Notice none of that long-winded reply mentioned doing actual lighting design. All about trying to make a profit on the switches, while denigrating a regular electrician.
The crux of the problem with automation systems is a lack of expertise on the part of the overall system design and usability. The devices are simple. Designing lighting plans is not, but the switches are a trivial part of the equation, as it installing them. Honestly, if someone can't figure out how to read Lutron's well-written documentation then they shouldn't BE an electrician. There's nothing at all complicated about the actual install of them. Not even for a homeowner (RA that is, QS tends to be more involved).
But once you've got these gizmos installed there's a HIGH likelihood you'll want to change how they're configured. No designer is ever really going to be able to plan ahead well enough. Sure, lots of thing can be done ahead of time. But you never really know how you're going to utilize an automation system until you actually live with it. And pardon me if this sounds insulting, but a field tech living in an apartment just isn't going to have the mindset necessary to grasp how someone actually LIVES in a million dollar house. So sending one of those "techs" out at $100/hour to "program" the system is, frankly, bull-sh1t. More like paying them $100/hour to learn how to live in the house. This should not be something the customer gets stuck with. Creston... I'm lookin' at you...
Yes, Lutron's homeowner options are good. But I'd argue they're really not enough.
Should these be done piecemeal like any other switches? Probably not. But are they something that should be entirely hands-off by the homeowner? NO! There's certainly middle-ground to be found here. Someone doing a comprehensive lighting plan for a house is WELL WORTH the investment. But I'd question if that same expense should be REQUIRED for the actual devices themselves. I'm certainly not playing it that way. But I've paid a fair bit to have a lighting consulting (that is a lutron dealer) work with me to design a system that will fit my expectations.
wkearney99 is offline
post #64 of 87 Old 08-05-2013, 09:53 AM
Sparkycoog's Avatar
As far as pricing goes, the retail prices are more or less the same so it's the dealer that ends up eating the cost since this is a consumer product and people can find it everywhere. Of course, if you're a company that buys tons of these things a year, you can bypass some of the hands involved but for an electrical contractor who does other things besides automation, you have to go through a dealer who goes through the local rep. Vantage cuts out one middleman but their stuff is pretty expensive too.
Being better for business if the customer messes up? I've had to clean up after a few people before, but some customers are just difficult so it's best to say no.
post #65 of 87 Old 08-05-2013, 03:51 PM
David Haddad's Avatar
Maybe they can watch some reality TV shows about people who LIVE in million dollar homes so that apartment living folk with tiny little brains such as themselves can attempt to grasp it. rolleyes.gif
David Haddad is offline
post #66 of 87 Old 08-05-2013, 04:02 PM
Sparkycoog's Avatar
Sorry, but millionaires still wake up and go to the bathroom in the morning and it wasn't a millionaire plumber that installed the toilet for them. They're not that special. All fancy society parties are about the same - plastic surgery, bartenders, servers, etc. programming a "party" scene and a "cleanup" scene is not rocket science so someone living in an apartment can still figure it out.
post #67 of 87 Old 08-06-2013, 11:35 PM
DDBear's Avatar
I appreciate that you're being straightforward about the real reason - their business model so homeowners are forced to go through the dealers. But there are some technical aspects that homeowners should still be able to adjust on their own, even with that kind of business model. For example it doesn't make any sense to me why I can't add or edit user logins or change the IP address without the dealer software. That aspect is just bad design.
DDBear is offline
post #68 of 87 Old 08-07-2013, 04:41 AM
Sparkycoog's Avatar
That gets complicated. If you try to change the IP settings and mess it up, or change user names and mess it up, you could be locked out of the whole system. It's all about balance between how the vast majority of the users will use the system and their knowledge of networking, programming, and electricity.
Also, keep in mind that we're talking about a fixture of the house and not just a fad toy. Many homeowners of the houses where I've installed these systems, the homeowners don't even care about the apps and just want the keypads to do what they want. Even when I try to explain the difference between a Room button and a Scene button most of them don't want to hear it. "When I push that button, I want those lights to come on" and that's probably how it'll be until they sell the house. If they push that button and it doesn't come on because their kid changed the programming on it, there will be hell to pay.
I can understand how some people want to do things themselves (heck, I only call for help when I'm in trouble or it involves plumbing or AC) but for the target customer base - wealthy people who like to eat sausage but not know how it's made), these systems are great.
Myself, I prefer Homeworks QS because I've seen the limitations of Radio-Ra 2 as the number of devices goes up and you have to add another main processor . For that, you have to be a Level 2 dealer (or whatever it's called) so many dealers can't even use it.
post #69 of 87 Old 08-12-2013, 07:23 PM
ddheyman's Avatar
Hi,
I'm trying to get the software as well. Would you be able to share it or recommend how I get a copy of the software?
David
ddheyman is offline
post #70 of 87 Old 09-03-2015, 04:44 PM
Liked: 0
For all googlers who found this forum like me, Lutron seems to now give away their software for free to homeowner.
Just google radiora software (I'm not able to post link).
Seawerst is offline
post #71 of 87 Old 09-03-2015, 05:43 PM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
It doesn't show when I look for it. Why can't you post a link? What's the header of the Lutron page?
schalliol is offline
post #72 of 87 Old 09-04-2015, 06:41 AM
XJBaylor's Avatar
Quoted: 117 Post(s)
Liked: 62
I searched and definitely cannot find a download of Ra2 Essentials/Inclusive unless I log into the dealer portal.
XJBaylor is offline
post #73 of 87 Old 09-04-2015, 07:02 AM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
I agree that at least L1 training is a good thing to require in order to offer the software. The bar is not that high.
post #74 of 87 Old 09-04-2015, 07:03 AM
rapamatic's Avatar
Quoted: 24 Post(s)
http://www.lutron.com/TechnicalDocum...L1%20BLAST.PDF
Take the course, pass the test, get the software. Homeowners welcome. Takes an afternoon.
rapamatic is offline
post #75 of 87 Old 09-04-2015, 07:08 AM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
Yep, that's great. It does however seem silly that the L2 is such a higher bar for what amounts to trivial changes. People need to be aware that if they have system professionally or otherwise installed with two main repeaters or uses L2-related components that taking the L1 won't help them in any way. There's no reason Lutron couldn't offer what's needed for L2 online.
post #76 of 87 Old 09-04-2015, 07:18 AM
rapamatic's Avatar
Quoted: 24 Post(s)
I agree that some of the L1/L2 distinctions are a bit arbitrary. I haven't hit any of the limits yet in my personal installation, but if I did I think I'd be able to find a way to get L2 certified. Lutron certainly has made L1 certification easier over the past few years, maybe we'll see the same with L2...
post #77 of 87 Old 09-04-2015, 07:25 AM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
L2 requires a $600 course that may not be in your city. For example, there's one date in Chicago in 2015 for this training and none in Indiana at all. It used to be that you had to submit details of two installations that you've done on RR2 and was not available to homeowners. I believe the language now just is that L1 is the only prerequisite.
post #78 of 87 Old 09-04-2015, 07:31 AM
rapamatic's Avatar
Quoted: 24 Post(s)
I agree it's still a pain, but getting better.
If you either 1) built a DIY system beyond the capacity of L1 or 2) had an inclusive system installed by a pro, then $600 is a drop in the bucket compared to the thousands you've spent on parts (or probably more if it was a pro job at retail prices+).
I'd actually be pretty excited for hands on training with Lutron. I'm sure they bring their A team to a training event like that.
post #79 of 87 Old 09-04-2015, 07:35 AM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
Fair enough, but generally people who spend that much on lighting control systems are less likely to have two days to give plus potential travel. I'm not saying it might not be worth it but that it's unnecessary. Perhaps make the deeper integration L3 that has on-site training, and have a L2 that requires 3x the online training detail as L1.
I suppose it's a different deal for people who choose to have an L2 system installed and want to add a component here and there from someone designing one from scratch.
post #80 of 87 Old 09-04-2015, 07:47 AM
rapamatic's Avatar
Quoted: 24 Post(s)
Yeah. My guess is a lot of people who had these systems installed wouldn't mind paying someone $500 to put in a dimmer on the new $5,000 chandelier in their dog grooming room.
I also bet that DIY are probably <2% of total RR2 installs, so we're not really the core of their market, and considering that, I think we've got a lot of accommodation from Lutron. They need to support their dealer/installers who drive the bulk of the business, and I'm sure its a very delicate balance...
But I do agree with you - I wish I could get the inclusive software and the more advanced hardware, and in all honesty at some point over the next few years as I keep building out my system, I probably will end up taking a class...
post #81 of 87 Old 01-13-2016, 12:03 AM
Liked: 1
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>jmaxbrod</strong> <a href="/forum/post/21765289"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
I believe you have misunderstood. I know of no dealer who leaves the software. Sometimes we have to travel too, I've sent my guys all over the U.S. for trainings, and I do a ton of traveling for trainings and shows as well. If you want a system, why can't you pay a dealer to come put it in? Your willing to buy hardware from them, and it's " your understanding" they leave software afterwords. You said its in someone's best interest to sell to you, so whomever told you they leave software is who you need to install yours.</div>
</div>
<br>
You can take a look through this forum and find many people who have had installers leave software for consumers. I am unaware of the license agreement, as I am not a dealer, but people report that installers indicate they can leave the software for the consumer within the license terms. The short of it is that I am interested in the products but not the installation services. I will not be a customer with installation costs as they are, and I have fairly knowledge of configuring similar systems and can do the minimal configuration I need (I just want to set-up dusk/dawn right now). I would be happy to attend a session online, like Hank's Electrical offers in person (I'd even pay something). I understand that many companies do not wish to do what I am requesting, and I understand why they do not. Clearly yours is one of those. To note, I have "sold" a number of people on custom installed systems that custom installers install and program, and I've been a CEDIA member in the past. So, those that are out there and interested, I look forward to your PM!
In 2011, I cheerfully purchased a RadioRA 2 system for a small boat house in Cental Illinois. I paid to have it installed. Since there were no programmers in our immediate area, I cheerfully hired a technician from Chicago to drive down and program it. Unfortunately, it quickly became apparent that some of the settings he recommended were not working for us. But we put up with them, since he was in Chicago. A year later, a switch failed. To have the replacement controlled by the system, it would have to be programmed. We found a programmer in the Peoria area who came and reprogrammed the entire system. However, he did not know to start over completely, and the system he programmed is very glitchy. Again, we just put up with it. Now, a second switch has failed. The central Illinois guy is no longer programming Lutron systems. I can hire a programmer from Indiana or Chicago. I'm no longer cheerful about paying hundreds of dollars to have a switch replaced, or to have glitches fixed. I am totally capable of setting up and maintaining this small system - if I am allowed to do so.
Beware of installing a Lutron system - or having a system installed for you - unless you live in a major metro area.
Yes, I want the program on my computer. No, I do not want to import expensive programmers everytime a switch fails.
bulls likes this.
SMcW is offline
post #82 of 87 Old 01-13-2016, 04:09 AM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
Good advice. Now that the software is available (well, essentials) with online training for free, this thread isn't really needed. I did take training when it was available, and my state has grown immeasurably since. I have continued to expand the system and know more about how the software and hardware works than many installers.
I also do a adjust programming to make tweaks pretty often, some of which could be done by mobile app, but some not so much. The system could not be easier to program with any technical ability.
Last poster, ask your installer door the file he/she uses and if for essentials, do the online training so you can get the software and make updates.
post #83 of 87 Old 01-13-2016, 06:27 AM
wkearney99's Avatar
Quoted: 342 Post(s)
Liked: 131
Yep, software can be obtained now, it's no longer just installer-only. You can even use the current software to import from the existing repeater's configuration.
I also find myself making tweaks, quite a lot less now. About once a season there's some small change I find useful.
As for a boathouse, outdoor and fluctuating environments (hot/cold/humid) are a challenge for any brand of lighting devices.
post #84 of 87 Old 02-27-2017, 01:10 PM
Liked: 0
I understand:
  • the RadioRA 2 design and programming software is unavailable to consumers;
  • certified installers/dealers have access to the software and are able to provide it to customers if they choose; and
  • installers/dealers that are not nearby my location would not be able to have me as a custom install customer.
As a result, I am looking for installers/dealers that have access to the software and would be willing to provide it to me if I buy hardware from them. Understanding I wouldn't get any support from them, it seems to be in their best interest to sell to me. Does anyone know of any such installers/dealers (not in Indianapolis)? Please either reply or PM if you know of any! Thanks!
UPDATE: I received PMs from several dealers and now have a system and software in compliance with the license agreement. Anyone in a similar situation, feel free to PM me and I can let you know what to do. I certainly recommend sticking with and supporting your dealer.
@schalliol , How do I get the RadioRA 2 software? I just installed Lutron shades and need to integrate with a non-Lutron home automation system.
pgattu is offline
post #85 of 87 Old 02-27-2017, 01:11 PM
Liked: 0
pgattu is offline
post #86 of 87 Old 02-27-2017, 01:20 PM - Thread Starter
schalliol's Avatar
Quoted: 51 Post(s)
Liked: 25
You can take training to become certified yourself or buy from a dealer who can provide a copy so you can make adjustments after install. Not all companies will do this.
post #87 of 87 Old 02-27-2017, 06:51 PM
wkearney99's Avatar
Quoted: 342 Post(s)
Liked: 131
STFW?
You sign up for a Lutron account (free). You take an online course, also free. You then get the ability to download the software, for free.
This will let you setup and configure a Ra2 project with up to 100 devices. If you want more than 100 devices then there's a paid tier of the software, or you work with an integrator. The bump from 100 to 200 does often come with enough complexities that it's worthwhile to attend actual training.
Sure, it seems easy enough to just throw things together... but not really.
Do you have an existing setup? Was that done by an integrator? It would be best to start with getting the project file from that integrator. That way you could load it right into the software and be up and running. Not all integrators will provide this, and it would be entirely reasonable to expect to pay a fee for it. Also know that it would also be entirely reasonable for them to inform you that support costs to untangle anything you screw up could be considerable. Likewise do not expect them to train you to use the software or answer questions about it.
The Lutron online training is pretty comprehensive but you do have to approach it with an understanding of how automation and lighting systems function.
Reply Home Automation
