RA2. Garage door opener recs. Easy to automate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-17-2012, 07:09 AM - Thread Starter
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I need to replace an electric overhead garage door opener.
I've seen mention of newer 'smart' models that are difficult to automate.
Any model recs, or features to avoid?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #2 of 4 Old 04-17-2012, 07:44 AM - Thread Starter
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I'll add that I'm using RA2, but would also like to control the garage door using contact closures.
When the RA2 VCRX RF Receiver is used with HomeLink, I think any opener with HomeLink would be fine, since the momentary CCOs of the VCRX wouldn't be used to control the opener. Correct?
Neurorad is offline
post #3 of 4 Old 04-18-2012, 07:39 AM - Thread Starter
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
For the record, Lutron TS said the Chamberlain Smart Control Panel would be shorted by the VCRX, when pulsed.
I'll skip the Chamberlain Smart Control panel.
Neurorad is offline
post #4 of 4 Old 04-18-2012, 06:56 PM
ELECTRICDON's Avatar
In any garage door integration you will need to abandon the fancy wall controls that the garage door installer provides and use a simple momentary contact wall control (doorbell push button or the like) then your integrator should be able to figure it out.
ELECTRICDON is offline
Reply Home Automation
