Panasonic plasma ST50 or ST30 IP control protocol? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-17-2012, 05:19 PM - Thread Starter
etc6849's Avatar
Quoted: 168 Post(s)
Liked: 124
Hi,
I just ordered a Panasonic plasma (TC-P60ST50) and would like the IP control protocol to control the set as I don't want to use a Global Cache WIFI2IR.
I haven't received the TC-P60ST50 yet, but I'm pretty sure it doesn't have the 3.5mm service port like the VT30 did so I can't use this document:
http://files.remotecentral.com/downl...era3d.zip.html
I share all of my work, so if someone helps me find the ip control protocol, I'll post the driver for download once it's complete at this location:
http://cocoontech.com/forums/forum/5...-home-control/
Of course, if it's a proprietary protocol and you don't want me to share it, I won't. In this case, feel free to PM me
I found this that seems to work for several of the Panasonic bluray players:
http://www.avsforum.com/avs-vb/showp...postcount=6256
It also looks like there is an android app called Viera Remote made by Panasonic. Has anyone packet sniffed and reversed engineered its protocol?
Premise, a FREE home automation program. Open-source Z-Wave Premise Module found here.
etc6849 is offline
post #2 of 2 Old 04-19-2012, 06:45 PM
znelbok's Avatar
I can't help unfortunatley, but I have a similar request for an LG TV.
While it has RS232, it would be easier to just use the one Ethernet connection for both control and data.
Mick
Illawarra Smart Home
The Integration Specialists
znelbok is offline
Reply Home Automation
