Lutron Maestro IR dimmer on 3-way switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-07-2012, 09:32 PM - Thread Starter
gulo's Avatar
Hello,
I would like to install a dimmer that can be controlled by my Harmony remote and I am looking at Lutron MIR-600M but I am confused about how to set it up on non single pole setup.
Here is my basement. There are 3 lights with 3 switches. Each switch turns all 3 lights on or off at the same time.
I always use the same one switch and I was wondering if I could just replace that one with Lutron MIR-600M and leave the other 2 in place or do I have to buy 2 companion switches Lutron MA-R-WH.
thanks
gulo is offline
Reply Home Automation
